chip and injecters
Old Jan 17, 2005 | 06:45 PM
need4speed's Avatar
need4speed
Default chip and injecters
had 4x4 cossie tuned today but its over fuelling, the tuner tryed to adjust the co level but as soon as it dropped it went straight back up.he reckons it could be a mismatched chip and injecters. its got green 355 injectors and the chip got nec 1990 on it.if i get a new stage 1 chip can i use the 355 or will i need standard injecters.thanks
Old Jan 17, 2005 | 07:41 PM
CosKev3's Avatar
CosKev3
Pretty sure will have to go to standard for stg1 m8
Take it the tuner checked all sensors are working as they should be?????????
Old Jan 17, 2005 | 07:42 PM
wimwerf's Avatar
wimwerf
for stage 1 you need standard injectors.....
Old Jan 17, 2005 | 07:44 PM
abdr500's Avatar
abdr500
have you got the right map sensor
Old Jan 17, 2005 | 07:56 PM
need4speed's Avatar
need4speed
where can i get std injectors from ,do ford do them
Old Jan 17, 2005 | 08:38 PM
Alvyn's Avatar
Alvyn
Default Re: chip and injecters
YOU CAN USE LIGHT GREEN (355) INJECTORS ALONG WITH A STAGE 1 CHIP AND 2BAR MAP SENSOR WITH NO PROB.
check that the map sensor(normally black in colour) is working properly or that the fuel regulator is ok
Old Jan 17, 2005 | 08:39 PM
cosworthbg's Avatar
cosworthbg
I have 8 std cossy blue injectors for sale m8,I also have a set of dark greens with stg3 ahmed chip for P8 for sale...
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Sep 29, 2015 05:04 PM
jonnyenglish
Sep 21, 2015 07:31 AM
RSmark84
Sep 13, 2015 01:29 PM
