No ignition lights sierra Sapphire
Old Jun 13, 2010 | 04:44 PM
pryde66's Avatar
pryde66
Default No ignition lights sierra Sapphire
I have parked my car up this morning and i was starting fine, came back an hour later and now it has no ignition lights. Side lights and hazard lights work and immobilizer is working, can anyone advise on what is wrong!!!???
Old Jun 14, 2010 | 01:25 PM
It would seem most likely the immobiliser is not working(as it should, ie not allowing starting), or are you saying it turns over and starts just doesn't show the normal ignition lights ?
Old Jun 14, 2010 | 01:31 PM
rog's Avatar
rog
Does it start???
If so, fuse 22 (If i remember correctly), 10 amp controls all the dash lights etc.
Old Jun 14, 2010 | 06:19 PM
martysmartie's Avatar
martysmartie
What he ^^ said, to confirm the number plate lights will also not work as fuse 22 protects these as well, if not the fuse check for corrosion or do a "Wiggle test".
Martin
Old Jun 14, 2010 | 06:49 PM
pryde66's Avatar
pryde66
There are no ignition electrics at all, no engine start, no indicators or anything powered by the ignition!!!! It wil not start at all!!!!
Old Jun 14, 2010 | 09:04 PM
xr_craig's Avatar
xr_craig
Sounds like an immobiliser problem then mate
Old Jun 15, 2010 | 07:19 AM
rog's Avatar
rog
Ok, as mentioned above no dash lights is a common problem usually caused by a fuse, but it won't effect the running of the car. As stated I suspect it's an immobiliser issue, but I'd pop the bonnet and check all the connections on the battery and the +ve lead off the battery to the starter etc.(might just be something simple) Are you sure it's not just a dodgy battery? Does the central locking work ok?
Old Jun 15, 2010 | 12:21 PM
martysmartie
Now that we know it will not start then as said it will be an immobilizer issue, if it were starter lead it would still have ignition, check that the CL still works with remote may just need a new battery in fob else probably a faulty fob.
Martin
SmudgerByName
52
Jul 28, 2016 06:14 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
pegaz
Aug 12, 2015 07:30 AM
Aug 9, 2015 07:03 PM
Old ford
Jul 31, 2015 06:50 AM
