2l zetec cooling problem
Old Jun 12, 2010 | 08:33 PM
n13los's Avatar
n13los
Default 2l zetec cooling problem
i have a x reg 2.0l mondeo, discovered a water leak today. i have cured that then i topped the header tank back to between min & max and let the car run up to temperature with the cap off to let any air out of the system. the temp gauge is working and was showing half way but at the point when the fan kicked in the water in the header tank started to boil and spew out of the top. let it cool and the tank was empty, so put 3 litres of water in and tried again with the cap on, again water was boiling and right to the top of the tank. removed the thermostat and tried agin, did exactly the same. thats where i have left it.
anybody got any ideas? im thinking the worst at the moment
cheers Neil
Old Jun 13, 2010 | 02:31 PM
Always run the zetec's with the cap ON, they run very very hot, best way is to top to minimum run up to temp, then leave to cool at least 2 hours, as it cools the pressure created in the tank draws out the air in the system, then just top to min again and off you go.
I suspect the 2 dreaded letters as you do H+G!!, head off moment it seems, just look VERY carefully for a small fisure(crack) in the cyl head as this is very common with zetec so will need a skim.
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
StephTell
Sep 2, 2015 06:31 PM
