1.8TDCI 2002. Thrust bearing.
Old Jun 11, 2010 | 01:40 PM
terrytimber's Avatar
terrytimber
Default 1.8TDCI 2002. Thrust bearing.
Have just bought a cheap focus tdci at auction. (Private buyer) and my mechanicky mate tells me the thrust bearing has gone. Is this common fault or am I one of the first up to 95k?
I have also got a misfire that is going to be diagnosed.
Does the engine have to come out to get at the clutch?
Thanks
Old Jun 12, 2010 | 09:03 AM
RichieST's Avatar
RichieST
How can he tell its gone without taking the box off and inspecting it? And no the engine doesn't need to come out to take the box off...
Old Jun 13, 2010 | 10:55 AM
terrytimber
Rich, I am NOT a mechanic, but there is a definate change in the engine note when you depress the clutch pedal to the floor and its out of gear.
Terry
Old Jun 13, 2010 | 11:27 AM
RichieST's Avatar
RichieST
They do whirr a bit anyway, especially when cold. If it were mine I wouldn't worry about it. All my opinion though, if you want to get it done for peace of mind then you may aswell.
I'd be changing the dual mass flywheel too while the box i off, these are a nightmare on the tdci's.
Old Jun 13, 2010 | 01:48 PM
terrytimber
OK thanks. I am going to sort out the misfire first because the symptoms might become less when the engine is running sweetly and then I will probably be able to live with it. Thanks for the flywheel tip.
Old Jul 13, 2010 | 03:31 PM
terrytimber
My problems disappeared after fitting dual Mass flywheel and clutch. Thanks for your help
Sp3no
Sep 27, 2015 07:23 PM
Damo
Aug 14, 2005 08:21 PM
escort frenzy
Jun 2, 2005 10:40 PM
Guy10sax
Jan 6, 2005 06:29 AM
Nov 21, 2003 05:46 PM
