compbrake adj tca's worn out in months!
Old Jun 10, 2010 | 03:28 PM
col93saphcos's Avatar
col93saphcos
Default compbrake adj tca's worn out in months!
hi,surely this is not normal,worn out with 9 month easily,only road use!
seemingly no warrenty with them,they're not interested,
what a rip off,just using standard tca's now as these adjustable ones have been nothing but hassle since day one,rant over,lol
colin
Old Jun 10, 2010 | 05:43 PM
KSA-Cossie's Avatar
KSA-Cossie
Hope mine last longer col.
Old Jun 10, 2010 | 05:56 PM
focus 4x4's Avatar
focus 4x4
Thats shit col
Old Jun 10, 2010 | 05:57 PM
kjc300's Avatar
kjc300
Originally Posted by focus 4x4
Thats shit col
I think mine are too
Apparently, you need to get the more expensive genuine ford ones off them.
Old Jun 10, 2010 | 06:31 PM
col93saphcos
heres hoping kev,
ye then the shitty little rose joint thats fit for fuck all will wear out!
colin
Old Jun 10, 2010 | 07:01 PM
robrs2's Avatar
robrs2
What is worn out?
I replaced the rose joints on the tca's I have with some form mcgill motorsport. One problem with using the rosejoints on the road is there not water tight. You need to fit the rubber over boots to keep the road crap out of the joint.
Old Jun 11, 2010 | 01:11 PM
Ridgey's Avatar
Ridgey
Not had a problem with mine after a couple of years and a few track days to boot.
Old Jun 11, 2010 | 01:58 PM
col93saphcos
ball joints knackered and rose joints not to healthy,and they have just had normal road use,wouldnt of said they had had a hard life either,at time i bought them didnt realise they made them with the better ball joint,so really they know theyre going to wear out quick! and their big ball jointed ones are dearer but i got the big ball jointed type about the same rice as the wee ones,
colin
Old Jun 11, 2010 | 02:52 PM
KSA-Cossie's Avatar
KSA-Cossie
Did you call tony about them col ?
Old Jun 11, 2010 | 05:23 PM
The word shit and compbrake are cropping up in the same sentence more and more lately.
You can get sealed rose joints, few more pennies that's all, as for the outer joint why did they simply not use another(sealed) rose joint, easy to do making a stand off pin, can still get arb attached as well.
If you want a PROPER set of adjusty TCA's pm me, and I'll pass you some details of a whizz maker.
Old Jun 11, 2010 | 09:41 PM
col93saphcos
ye,im not convinced about there stuff,
thats what i fancied,rose jointed both ends,didnt know if it was possible,but would there not be more movement on a ball joint than a rose joint?
will pm you soon,once i work out what im doing with my handling quest,lol
colin
Old Jun 12, 2010 | 11:40 AM
Movement wise the rose joint, OR a decent ball joint will have plenty enough, with a rose joint you use a stand off pin.
Old Jun 12, 2010 | 12:09 PM
JonnyBravo's Avatar
JonnyBravo
Compbrake are I believe who TAS were, if thats true then the quality of their products would be explained !
I've seen rack mounts from them that didn't even clamp the rack tight ! I've just had a set of top mounts through from another supplier who decided not to tell me they were Compbrake items, had I of known I'd of got them elsewhere.
Old Jun 12, 2010 | 12:48 PM
dingla rs's Avatar
dingla rs
can you get one's with rose joints both ends then??
gingeRS
17
Oct 2, 2015 09:42 AM
rsguy
44
Sep 29, 2015 03:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
Topjoe9
Sep 12, 2015 09:50 AM
