what oil breather are you using? what way have you plummed it in?
Old Jun 6, 2010 | 02:47 PM
andy130's Avatar
andy130
Default what oil breather are you using? what way have you plummed it in?
seen alot of people have plummed there in other ways so what the best way to do so? which one are you using?
cheers andy
Old Jun 6, 2010 | 03:23 PM
gus's Avatar
gus
custom pro alloy one in mine
pic shows pipe work unfinished tho
Old Jun 6, 2010 | 04:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
So long as you have crank case gasses going in (rocker cover fed), a return to the sump for condensed oil vapour (back of block), and either one to atmosphere (little filter) or recirculating (metering unit or EFI inlet manifold) it doesnt make bugger all difference IMO
Old Jun 6, 2010 | 05:40 PM
morph's Avatar
morph
gus thats a lovely engine!
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
