FAO Tony (Nuts RS)
Old Jan 16, 2005 | 11:39 PM
RichardPON's Avatar
RichardPON
Default FAO Tony (Nuts RS)
I know you're the man who can, so I wondered...........
Can you, or anyone you know get hold of Red Top batteries?
What do you run on your car?
Old Jan 17, 2005 | 12:39 AM
NUTS RuS's Avatar
NUTS RuS
I run a red top 40 Rich.
Increased it last year as the 30 was struggling a little with the compression when hot.
Info here http://www.mdsbattery.co.uk/shop/pro...ctGroupID=1085
Got my old one knocking round if you need to try it. It wont fit in that box you have, but can get specific ones made for the red tops
**Edit** Just to say with these you dont necessarily need a battery box and can lay them down on their side etc
Old Jan 17, 2005 | 12:56 AM
NUTS RuS's Avatar
NUTS RuS
The old one....
The new one....
Old Jan 17, 2005 | 05:24 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
As Tony advised me too, I got mine from MDS too....
Old Jan 17, 2005 | 06:02 PM
RichardPON's Avatar
RichardPON
Nice one lads!
Okay, second question as Markk suggested the other day.
Is the terminal okay to handle all the current draw, as it's not particularly big?
What about charging and recharging? If they go flat, are they fooked?
Old Jan 17, 2005 | 06:14 PM
NUTS RuS's Avatar
NUTS RuS
M6 male terminal is more than plenty If your in anyway worried you can put a small nut on first, then a bigger washer, then your cable, then a washer then the top nut But you won't need to.
If they go flat they can be trickle charged with low amps with no loss of performance. What they dont like when flat is a heavy or boost charge, and thats where people make mistakes with them.
When not in use I have one of those milliamp solar panel chargers connected and it keeps it in tip top condition.
Old Jan 17, 2005 | 06:37 PM
RichardPON's Avatar
RichardPON
They're not fookin cheap!
Do you think the 40 should be okay? - still running stuff like leccy windows (I know ) and an alarm.
I presume also, because they're gel, there's no need to box them?
P.S. Just noticed it's "Nuts RuS"
Old Jan 17, 2005 | 06:59 PM
NUTS RuS's Avatar
NUTS RuS
Whats the current cranking amps of your wet cell battery Rich ? Go for a similar match to that if it used to be okay. Leccy windows make no difference as you generally are not operating them when cranking the engine.
Yep because they are sealed and contain no liquids there is no need to box them and no gasses are produced so they are 100% safe.
Mine lives behind my seat for central low down weight distribution, and to have that comfort and piece of mind I would pay any price.
Names make no difference Im still me
Old Jan 17, 2005 | 07:09 PM
RichardPON's Avatar
RichardPON
I don't know what the current cranking amps are at the mo.
Behind the seat it is then - that should make installation nice and easy!
Old Jan 17, 2005 | 08:16 PM
DazC's Avatar
DazC
Rich,
You could always parrallel up a couple of batteries if you are worried about electrical drain on them.....
Old Jan 17, 2005 | 08:22 PM
AlexF's Avatar
AlexF
Rus...
Could I be rude and try your old 30 on the mini?
alex
Old Jan 17, 2005 | 08:25 PM
NUTS RuS's Avatar
NUTS RuS
NP Alex Will have to check if its not gone flat first tho
Its at work and Im not back in until next week (working away from office atm)
Old Jan 17, 2005 | 08:35 PM
AlexF's Avatar
AlexF
cheeRS!
Watch a star you are
Shame its not till next week... I'm driving past this weekend
alex
Old Jan 17, 2005 | 08:51 PM
RichardPON's Avatar
RichardPON
Daz - not sure what you mean?
TWO red tops?
They're Ł180 a piece
Old Jan 17, 2005 | 08:59 PM
AlexF's Avatar
AlexF
just buy a bigger red top in the 1st place Daz!
alex
Old Jan 17, 2005 | 09:11 PM
DazC's Avatar
DazC
TWO red tops?
Yes, 2! Ł180 each?!? BARGAIN!!
You connect both negatives together and both positives together (parrallel) then just connect your pos battery cable to one of the positive terminals and the neg battery cable to one of the negative terminals. This will DOUBLE the amps capacity that the batteries can supply (as long as you use 2 the same size)...
N.B. If you wire them in series it will double the volts so don't do ithat way!
Or just get the Red Top 60!
Old Jan 17, 2005 | 09:20 PM
RichardPON's Avatar
RichardPON
Ł360 on batteries?
Fook that
40 I hope should be enough
Old Jan 17, 2005 | 09:32 PM
DazC's Avatar
DazC
The 40 should be good enough although I am not willing to throw my hat in the ring and say it will be!
Once running your alternator should take over the current draw of the electrical systems. I would advise you get the alternator tested to make sure it has the 90 amp reg in it and not the 60 amp that I find a few Cossies have been poked with. 60a is not strong enough with everything switched on, though I will assume you won't have things like front fog lamps or heated screens on your car? If not then electrical demand won't be as great although this could be counter balanced by additional fuel pumps etc....
Old Jan 17, 2005 | 10:18 PM
NUTS RuS's Avatar
NUTS RuS
Current draw on the wallet sounds more the problem Daz
Alex - leave it with me
Old Jan 17, 2005 | 10:32 PM
DazC's Avatar
DazC
It's always a bastard is that, isn't it!?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie330
Oct 7, 2015 08:22 PM
DavidK
Sep 27, 2015 02:55 PM
