injector flow checking
Been having some trouble with over fuelling, my chip & l6 are currently at msd for checking so i thought it would be a good idea to get my greys checked.
Anyone recomend any companies around the herts / london area ?
Also what sort of money should i be paying and also what sort of flow rate should i be expecting on the greys ?
cheers paul
cheers paul
aren,t greys 503,s meaning 503cc per minute? i know joe at bluesprint does loads of these injectors has the equipment to test , based in maldon
he,s number 01621 744881 .
hth
Mike
hth
Mike
Number does NOT dictate flow rate, ie dark greens flow much less than greens despite being 803 and the greys 403's.
Most charge around £50-£60 to clean/flow check, the point of cleaning is to ensure they are even, often it reduces the flow, as there are no deposits causing the open close pintile to be slowed.
DixieTheKid
11
Jun 6, 2020 11:20 AM
