MSD poly diff mount help
Old Jun 3, 2010 | 03:13 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
Default MSD poly diff mount help
Just bought one of these
Lovely bit of kit but it wont fit my 2wd saff as it fould the ARB
I heard you can get a flush fit bolt kit but don't know where from
Can anyone point me in the right direction
cheers
Old Jun 3, 2010 | 03:26 AM
2wd's Avatar
2wd
cheers
You can get it from Mike Rainbird from here or "silvercos" from the escortrscosworth.com
Old Jun 3, 2010 | 04:58 AM
ShiftyOldScoob
Thanks for that mate
Old Jun 3, 2010 | 08:20 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Still not fitted mine
Had it since December lol
Steve
Old Jun 3, 2010 | 08:23 AM
James @ M Developments.'s Avatar
we do the modified bracket for these aswell! ours gives the most clearance, give us a bell mate
Old Jun 3, 2010 | 02:14 PM
opposite lock's Avatar
opposite lock
would the flush bolts not be required with this modded bracket ? i,ll be ordering one + bolts if you do them
cheers
Mike
Old Jun 3, 2010 | 02:24 PM
the modded brackets come with the flush bolts
Old Jun 3, 2010 | 05:27 PM
Maybe the std bush re-inforced with poly for £50 that is 100% same size might fit better, no exterior size difference at all, just has the voids filled with poly so you know everything fits perfect.
Old Jun 3, 2010 | 05:28 PM
Steve
Seriously need to get it on the difference is unreal, whoever's poly one you use will be awsome improvement.
Old Jun 3, 2010 | 07:43 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Sounds like i will need new bolts before i can fit it
One day it will be done
Might get a bit of traction in 2nd then
Steve
Old Jun 3, 2010 | 07:52 PM
ShiftyOldScoob
James I'll give you a bell tommorow mate!..didnt think I'd need the kit at first but I discovered I have a 22mm anti roll bar...result
Tabetha, I had considered geting the standard one done but I couldnt find anyone local to do it
Old Jun 3, 2010 | 08:51 PM
bad boy rs's Avatar
bad boy rs
They do atchualy fit with the supplied bolts but you get a bit of knocking, little bit annoying but cant be arsed to change mine to the flush kit
Old Jun 3, 2010 | 10:20 PM
plynchy's Avatar
plynchy
Just fitted mine tonight, diff now appears to be welded to the floor rather than flopping about.
Also fitted a Bayjoo track spec spring kit from R&B, difference in handling is unreal. Well impressed.
Old Jun 4, 2010 | 03:03 PM
If you had done the diff mount on it's own, you'd see this makes so much difference stops 99.9% of the rear steer action on bump and rebound.
Old Jun 4, 2010 | 03:06 PM
I can get these done no probs, matey in Iceland has one on his 3 door 1/4 mile car, these fit with the 22mm arb and a tow bar with the large "U" shaped bracket these use, as mine has all this, as the std bolt heads are recessed quite a bit there are zero clearance issues with any size of arb, it's also very appealing for the bufties as it looks std, it's filled with black poly, or other colours if you want.
Old Jun 4, 2010 | 03:21 PM
RS SHAUN's Avatar
RS SHAUN
ive just fitted a flo-flex diff mount with no problems, plenty of room
cheers shaun
Old Jun 4, 2010 | 06:02 PM
plynchy's Avatar
plynchy
That diff can't be in use, it's far too clean.
Old Jun 5, 2010 | 05:26 PM
RS SHAUN's Avatar
RS SHAUN
just abit of paint mate
cheers shaun
Old Jun 5, 2010 | 05:37 PM
bad boy rs's Avatar
bad boy rs
I spot a secret bufty
Old Jun 5, 2010 | 06:34 PM
RS SHAUN's Avatar
RS SHAUN
Maybe just a little bit, just waiting for new tank to arrive
Old Jun 5, 2010 | 07:07 PM
plynchy's Avatar
plynchy
To paint it it needs to be claen in the first place........I rely on my diff to rustproof the rear of my car.
Hope you haven't paid more than £60 for your tank, i've recently had one delivered for that.
Old Jun 5, 2010 | 07:41 PM
RS SHAUN's Avatar
RS SHAUN
Got tank off trickydicky on eBay mate
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
