ST170 Back On The Road *Verdict*
Old Jun 2, 2010 | 10:44 AM
Sp3no's Avatar
Sp3no
Default ST170 Back On The Road *Verdict*
I have not driven my ST170 since i did the following work
New 40 Groove Disks
Red Stuff Pads
Stainless Steel Hoses
Short Shifter
Tweeked Exhaust Cam Timing to 8degrees retard
Polybushes all round including rear blade bushes and anti roll bar end link bushes all exhaust hanger and rear engine mount.
Alloy Crank and water pump Underdrive Pulleys (water pump pulley larger to gear it back up)
New Track Rod Ends
New Wishbones with Bottom Ball Joints
Underside nut and bolt restoration, new handbrake cables, stone chipped, everything painted etc.
Full service including brake fluid, and powersteering fluid change.
Serviced my K&N Typhoon induction kit.
Cam belt change including all tensioners
Aux belt change.
The car was making 189bhp before the underdrive pulleys and the additional tweeking on the exhaust cam.
The pervious spec was
Eibach springs
Mongoose Cat Back System
Typhoon Induction Kit
Dreamscience Remap
Ported Throttle Body
Clutchmasters 12lb Aluminium Fly Wheel
Clutchmasters Stage 3 Kevlar Friction Plate and uprated Pressure plate
CFM Exhaust Cam Pulley 4 degrees retard
I dont know if there was something wrong before i made all the changes but my god does it feel quick now i was not expecting to notice any difference but there is a MASSIVE difference. Especially in acceleration, before i was getting rough 0-60 times of 6.8/6.9 but now it is more like 6.4/6.5 as soon as the manifold switches over at high RPM it goes like a rocket and there was never this surge of power at high RPM before. With the bushes there is a very noticable change in the stiffness of the car, no increase in road noise, it has reduced if anything. When taking a roundabout at high speed the car does not lean anymore, you can feather the throttle and skip and slide it in a controlled manner. The exhaust note has changed, it sounds and feels raw. The idle is a bit lumpy due to the overlap on the valves but i think it sounds as though it means business lol
The short shifter is a joy to use it has a very short throw but is so precise, its the first time i have used a shoft shifter and i think its brilliant
Im loving it apart from the fact it returned 19MPG yesterday £20 of fuel gave me 70 miles!! Think it was down to my excited driving
This is as far a i feel i can take the engine now without high RPM (not good without dry sumping) and bodies or Forced induction, power wise it must be in the mid 190's. Im a bit sad that there are very few power gains left avaliable without major work so im already planning next years turbo conversion
All in all its like a new car and so much fun to drive. Its not the fastest car on the road, far from it but its so much fun, i would describe it a very nippy lol this is how they should have come out the factory. I think it is going to continue to upset supposedly faster cars for a while now at least
The best bit for me though was after having the car in so many bits, apart from a ball joint slipping out on the driveway it has been perfect, not a bang, knock or rumble, nothing has fallen off, not ever a fault code for the VVT solenoid which is common after a cam belt change. A personal Triumph
Old Jun 2, 2010 | 10:52 AM
TomStarkey's Avatar
TomStarkey
I think if i'd have attempted that i'd have a ad up "st170 for sale - spares only" lol
Old Jun 2, 2010 | 11:14 AM
scortpower's Avatar
scortpower
where did you get the cam pulley from to adjust the timing?, i am guessing this cant be done with the normal cam pulley. I am after getting some 'go' out of my 170
Old Jun 2, 2010 | 11:38 AM
Sp3no's Avatar
Sp3no
I have been importing all my Bits from Central Florida Motorsport (CFM) in the states so my Clutch, Fly, Short shifter, Bushes, Underdrive Pulleys and Cam pulley all came from there.
In hindsight i would save up and order all the bits at once as i got stung for Import tax with every order, BUT it was still cheaper than Puma Speed. Puma Speed stock all the CFM gear but a massively inflated prices. You can get a Vernier Cam pulley from Piper i belive but they are around £100-110
I liked the CFM one because it had the most locking screws, the CFM one works out at £75
Old Jun 2, 2010 | 03:10 PM
hineho87's Avatar
hineho87
did u notice much difference from the underdrive pulleys or is it hard to tell with changin the cam pulleys as well?
Matt
Old Jun 2, 2010 | 04:07 PM
Sp3no's Avatar
Sp3no
Obviously getting the Cam Timing spot on has helped but i do think that the underdrive pulleys have released some extra power, no doubt they have helped a bit on acceleration. The car is allot quicker and it cannot be down to just the cam timing
Old Jun 2, 2010 | 04:19 PM
RichieST's Avatar
RichieST
Sounds good mate. Loved the handling of my old 170, just a shame ford decided to put a wet blanket under the bonnet instead of an engine. Good to see you've made a big improvement to it!
Old Jun 2, 2010 | 04:34 PM
Sp3no's Avatar
Sp3no
The engine in its standard trim is a bit disapointing lol. it should have had 190-200 in factory form. We cant all have a mans engine like you rich, some of us have to make do with just 4 cylinders lol
Old Jun 2, 2010 | 04:54 PM
hineho87's Avatar
hineho87
cheers for the reply m8, iv only got a 1.8 but full mods on it (cams etc) and jus not sure if spend money on the cfm underdrive 2piece kit. Some people say im wastin my money so not sure whether stop spendin and keep the money back for wastin on my st3 when i get it next yr
Old Jun 2, 2010 | 07:22 PM
scortpower's Avatar
scortpower
will have to look into doing it. mines only got filter and exhaust but still needs that kick in the arse to get it moving. thanks for the reply
Old Jun 21, 2011 | 12:12 PM
kyle_st200's Avatar
kyle_st200
If you get the underdrive pulleys or the vernier pulley let me know as Im in 2 minds wether to do this to mine
turbojoe69
Sep 17, 2015 07:07 AM
Toe Knee
Aug 23, 2015 08:31 AM
turbojoe69
Aug 18, 2015 06:41 AM
Sultzi
12
Aug 16, 2015 01:08 PM
