what spark plugs for a chipped ERST
Jan 16, 2005 | 07:37 PM
As the title really please, need a new set before going to the rollers.
Cheers PaulT
Jan 16, 2005 | 07:57 PM
Jan 16, 2005 | 09:03 PM
lmfao!
"2.0ZVH
original are the best!"
Why you do 2.0zvh then?!
i use ngk's in mine is fine once its started! just have problems starting!
Jan 16, 2005 | 10:17 PM
Champion QC59YC or QC57YC. 57 is better on really hot days. 59 is better alround.
Jan 16, 2005 | 10:18 PM
i use and recommend champions c57
Jan 17, 2005 | 10:18 AM
many thanks
for all the replies i just been out and got some c57s see how we go with them.
Cheers PaulT
Jan 17, 2005 | 02:33 PM
james not on about the eng,on about s1, the original (1st) rst are better than s2 imo..
Jan 17, 2005 | 04:29 PM
make sure u set gap at 28 its very important
Jan 17, 2005 | 10:31 PM
I use N.G.Ks no probs
Jan 31, 2005 | 07:56 PM
WAS RECOMMENDED BY POWER ENGINEERING 2 USE NGK BCR 8ES,REMOVED A BRAND NEW SET OF CHAMPION C59C AND FITTED THESE WHEN WENT 4 ROLLING ROAD TUNE,ONLY A TENNER COMPARED TO £30 FOR CHAMPIONS
Jan 31, 2005 | 08:23 PM
i use NGK BCR8ES, can anybody recomend the best gap setting for a 18+ psi motor.
Feb 1, 2005 | 09:34 AM
iv heard bad things about champion plugs-breaking down etc.i use NGK with no problems at all.would reccomend.
Feb 1, 2005 | 12:36 PM
BCR8es are just standard plugs.. the spark CAN blow out on them when running a lot of boost
the BEST plugs for an RST running a lot of boost are NGK 9's or the equivellent new ones but they are arround £100 a set i have these in my car and they are
Feb 1, 2005 | 08:54 PM
GAP for 16psi ngk`s BCR8es please
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
