abs problem on 4x4 saph
when first start up light goes off and when u drive below say 20mph brake pedal keeps kicking back as if its skiding then light will come on after 20mph and brakes work fine and pedal feels ok? Any ideas?
might be a bit of dirt on the abs sensors or the pick up rings on the drive shafts. Good luck trying to get the sensors out cause they seize in the hubs. It might be best if you take your driveshafts out and clean the abs pick up rings.
DixieTheKid
Jul 23, 2023 10:16 AM
jdsjojo
Aug 30, 2015 07:48 PM
