Replacement Head studs
Old Jan 16, 2005 | 06:09 PM
boXXer's Avatar
boXXer
GASH!
Default Replacement Head studs
A few of the head studs are missing off the exhaust side of my cossie. Does anyone make a sooper dooper, non rust one that wont be a bitch to get off in the future? or shall i just go to fords and get some original ones......
Mike.
Old Jan 16, 2005 | 06:10 PM
TIFF's Avatar
TIFF
Chasing Radders
Get some Original ones mike
Old Jan 16, 2005 | 06:11 PM
boXXer's Avatar
boXXer
GASH!
cheers bud.
Old Jan 16, 2005 | 06:13 PM
boXXer's Avatar
boXXer
GASH!
whats the easiest way to get the old shitty ones out??
Mike
Old Jan 16, 2005 | 06:35 PM
Alvyn's Avatar
Alvyn
DONT forget your cheque book for the studs and nuts from Frauds
easiest way to remove the old studs is to put 2 of the nuts on and undo the stud
Old Jan 16, 2005 | 06:36 PM
TIFF's Avatar
TIFF
Chasing Radders
As said, put 2 nuts on and pinch them together so you can undo them out...........................................If they come out
boXXer's Avatar
boXXer
GASH!
when the stud has 1mm left on it, its quite hard, lol. I think im gunna have to use a easy out to get them out.
Mike.
Old Jan 16, 2005 | 06:59 PM
Ginge !'s Avatar
Ginge !
just finding my feet
if they snapped then thats not good
thats a pricey job to have done
how long they been snapped for ???
Old Jan 16, 2005 | 07:08 PM
boXXer's Avatar
boXXer
GASH!
a while by the looks of it. Some tosser has snapped off the studs at the bottom of cylinders 2,3,4. So now i have to get them out.
Old Jan 16, 2005 | 07:15 PM
TIFF's Avatar
TIFF
Chasing Radders
Oh Dear
You may as well put a new head gasket on it then while the head is off and being helicoiled
Ginge !'s Avatar
Ginge !
thats the turbo dampner prob again
Old Jan 16, 2005 | 07:19 PM
boXXer's Avatar
boXXer
GASH!
Originally Posted by TIFF-C20WTH
Oh Dear
Yeah ive just been speaking to my dad about it. i think im gunna have to take it all off, and replace it as neccesary. May aswell to valve stem seals (if they have them), and the cam oil seals while its all off. Oh well.
Old Jan 16, 2005 | 07:21 PM
TIFF's Avatar
TIFF
Chasing Radders
Aye mate
Like i said, put a headgasket on it while your there, do it once and do it right.
Old Jan 16, 2005 | 07:23 PM
boXXer's Avatar
boXXer
GASH!
yeah thats what i was thinking. I dont wanna be taking it all apart again in the summer if the std headgasket goes. think im gunna go for a grp a headset. Do they come with cam oil seals?
Mike.
Alvyn's Avatar
Alvyn
that IS bad luck m8
also NOT done by sum 1 all the time as u have said as it is common for these to snap unfortuatly on 2w/d manifolds as the studs DO work loose over time due to the heat etc !
Old Jan 16, 2005 | 07:27 PM
TIFF's Avatar
TIFF
Chasing Radders
Mike
If you are not looking at going for anymore power get a Late Escort Cosworth Head Gasket
Cam seals are a few quid from Fords mate
And get a Cometic Rocker cover gasket as they are reusable i think
Old Jan 16, 2005 | 07:39 PM
boXXer's Avatar
boXXer
GASH!
but they have snapped half way through, not at the head. look..........
The longer one circled has been replaced sometime before, so its all been off once already.
Mike.
Old Jan 16, 2005 | 07:40 PM
Ginge !'s Avatar
Ginge !
but not the head gaskets
late escos is a group A aint it
Old Jan 16, 2005 | 07:42 PM
TIFF's Avatar
TIFF
Chasing Radders
Ginge
Fookin too right
and
Yes
boXXer's Avatar
boXXer
GASH!
thing is, if i buy a whole headset from burtons, it will have all the bits i need like inlet gasket, oil seals, and other stuff, unless ford do one???? any suggestions?
Mike.
Old Jan 16, 2005 | 07:44 PM
Alvyn's Avatar
Alvyn
Mike.
If u can get 2 of the nuts onto the threads then u should be able to undo while head is still on if only a little bit showing then try a pair of good molegrips
TIFF's Avatar
TIFF
Chasing Radders
Yes mate, go for the Burtons Group A gasket set.
I thought you was just getting a head gasket.
Get the full set and do all of them, thats 1 job less to worry about
Old Jan 16, 2005 | 07:46 PM
boXXer's Avatar
boXXer
GASH!
yup. Cheers for all your help on my posts tiff. and everyone else that has helped.
Mike.
Old Jan 16, 2005 | 07:48 PM
Ginge !'s Avatar
Ginge !
Mike.
please note he said GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD GOOD pair of mole grips !!!!!!
Old Jan 16, 2005 | 07:52 PM
boXXer's Avatar
boXXer
GASH!
pmsl, yeah, hydraulic powered ones.
Old Jan 16, 2005 | 07:54 PM
TIFF's Avatar
TIFF
Chasing Radders
No probs Mike
All part of Team NMS
Old Jan 16, 2005 | 08:00 PM
boXXer's Avatar
boXXer
GASH!
you know that. i was gunna ask him for a sticker, but forgot when i saw him.
Old Jan 16, 2005 | 08:02 PM
Ginge !'s Avatar
Ginge !
Old Jan 16, 2005 | 08:09 PM
boXXer's Avatar
boXXer
GASH!
oi, leave me and my stickers alone.
Old Jan 16, 2005 | 08:51 PM
Ginge !'s Avatar
Ginge !
well wait till ya see my sticker on wednesday , thats the one ya want !!!!!!!!
Old Jan 16, 2005 | 09:48 PM
abdr500's Avatar
abdr500
what you can do is get a very good molegrips and get a torch on the stud and heat it up until it glows red and simpley undo it it sould come out easy once heat is put on ther you can b a brenzomatic gas can from b&q s for Ł15 that will do the trick just light it up and heat it no need for head off not unless you what to
Old Jan 16, 2005 | 11:23 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Mike, do you have a turbo damper on yours ? If not, it may be a worthwile investment, I think they are supposed to help with studs snapping, etc...
Can anyone explain why the std ford studs are ok ? I bought and fitted a set of stainless ones on my 4x4 and was just wondering if they were really worth the extra wonga.
Good luck with the rebuild mike, our 2wd is going to have the same treatment very soon.
Old Jan 16, 2005 | 11:25 PM
RANJ's Avatar
RANJ
if ur whipping the haed of, and u go the funds, might aswel get some headwork done
Old Jan 16, 2005 | 11:27 PM
where tho....
Guess karl can do it
Old Jan 16, 2005 | 11:28 PM
RANJ's Avatar
RANJ
if he wants to i suppose
Old Jan 16, 2005 | 11:31 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
