3dr help please
Old May 29, 2010 | 08:59 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default 3dr help please
My mate has just bought a 3dr cossie with the engine out the car etc ive fitted the engine back in today and plumbed it all up etc.
But now the problem there is no spark or power going to the fuel pump at all,does anybody have any idea what the problem could be?
cheers
Old May 29, 2010 | 09:07 PM
The Youth.'s Avatar
The Youth.
check the ecu is switching the fuel pump relay
steve
Old May 29, 2010 | 10:51 PM
Rsmat's Avatar
Rsmat
nice diagram steve,
Old May 30, 2010 | 07:44 AM
big ord's Avatar
big ord
give me a ring going away at 1200 oclock so will call in if rogger will be up and i will have a look
Old May 30, 2010 | 08:24 AM
gazcos's Avatar
gazcos
I had this on mine ,turned out to be the Immobiliser mucking about.Wouldn,t start all day. Left it for a few hours and it seemed to have sorted itself out.
Old May 30, 2010 | 09:08 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
No spark and no fuel pump - CPS?
Old May 30, 2010 | 09:32 AM
COLEYST200's Avatar
COLEYST200
is the loom pluged in to power up the ECU its behind the glove box
Old May 30, 2010 | 09:41 AM
Dicko&Vacant
yeah loom is pluged in to ecu even tried another ecu
Old May 30, 2010 | 09:54 AM
t4 and greys's Avatar
t4 and greys
cosworth gimp
cps or make sure the dizzy plug and the cps are not mixed
Old May 30, 2010 | 09:55 AM
Captain500rs's Avatar
Captain500rs
You not at Finns and Chrome today mate?
Old May 30, 2010 | 09:56 AM
bad boy rs's Avatar
bad boy rs
has the 3dr got an inertia switch in the boot ?
Old May 30, 2010 | 10:01 AM
R4N SS's Avatar
R4N SS
no inertia switch on 3dr
Old May 30, 2010 | 10:16 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Does the fuel pump prime when the ignition is first switched on?
If so and there's no fuel pump on cranking, it does indicate a fault with the crank sensor or wiring. If the crank sensor isn't working, you won't have a spark or fuel pump operation.
Old May 30, 2010 | 10:21 AM
vroooom ptssssh
It Wasnt Me!
Also, does this not apply to the ignition amp if no fuel pump or spark?
Old May 30, 2010 | 04:35 PM
Dicko&Vacant
The pump dont even prime mate,im going back over tomorrow to have another look so ill try cps etc
Old May 30, 2010 | 05:04 PM
payney's Avatar
payney
just had the same problem with the fuel pump and it was my ignition amp not earthing properly
Old May 30, 2010 | 07:50 PM
tomoyb's Avatar
tomoyb
the ignition module needs to be mounted on the heatsink plate with a paste
i know of a melted ecu after 500miles on a new build due to garage mounting it direct on inner wing
Old May 31, 2010 | 08:51 AM
I got told about this car yesterday of the cleveland rsoc lot.I hope you get it sorted fella.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Sierrasideways
Oct 8, 2015 06:37 PM
martynhomer01
Oct 1, 2015 12:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
