spotted at turbosystems
thanks madrod for your p.m. i hope mark appriciates your support. i look forward to marks post on my slur (as you put it) on his mapping. why the customer chose to go to tony and not mark was his choice.
two values i was taught was. Tell the truth,Respect your elders. i do both.
(forgive the spelling.)
Im sure Mark will give all the facts when he gets in tonight.
I never mapped the car I only supplied a base map and having told wes I dont have base map to suit his spec it will need work and no cost for the base map,
Then a upgrade to a 1.09 ecu chip and again I have not run this chip with a 36-1 pully and the trigger patterns in the software have been totaly rewriten and this may need work to get it started,
This may have only taken me 20mins to sort if it had not run correctly but as not seeing the car its a bit difficult to do this
So according to you I am a shit mapper
but the fact is you cant map a car you havent seen
.Mark
I think you must have mis understood what you may have been told but the facts are,
Mark
.Mark
autronic has gone to 36-1 now mark ?
why do you think they did not do this originally ??
JTFC
Just to clear things up, I purchased the ECU from TurboSystems who got it from MAD, supplied with a base map to get the car running. The car started on the 1st attempt. I then got the firmware version of the ECU updated to v1.09 and Mark didn't have a working base file for this firmware and my sensor setup, he changed a lot of the settings required when going from 1.07 to 1.09 but as with anything it is difficult to get these things 100% right without having the car in front of you to verify, the car didn't start after the firmware update so I played around with some sensor settings to get it running again. Mark hasn't done anything wrong, he's never even seen the car or done any work on it! He's always been helpful with any questions Ive had.
I took it to TurboSystems to give the car a bit of a once over and to do a bit of work on the base mapping as it was stalling when revving the engine and coming off the throttle and the Idle was going abit mental from time to time, we have solved these little problems now, once Ive got the car back on the road and run-in it will be going back to Tony for mapping as he is my preferred engine mapper, simple as that really!
Yes std Weber uses 4 on a 4 cyl engine, Autronic prefer to use 2 on a 4 cyl, something to do with it not actually needing as many inputs, but it can use various configurations and does work with 36-1 as my car runs. I was already using all of the small turbo escort pulley's + sensors before i even got the ECU so seemed silly to change them if not required.
so "a rs licker" has slated someones work and then the actuall owner (wes) has come on here to say MAD hasnt done anything wrong?
talk about chinese whispers! - if that isnt a lesson in having all the facts, then i dont know what is!!
So you have seen the replies and were is the sorry I was mistaken and have taken it up with the person who made the mistake by tellin me incorrect info
Mark
