AVO rear suspension?
Old May 29, 2010 | 08:46 AM
R5FORD's Avatar
R5FORD
Default AVO rear suspension?
Anyone had and trouble fitting it up in the rear?
Im having a hard time getting the top part into the turret ( where the bolt goes through in the boot)
Old May 29, 2010 | 12:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
spray wd40 or a similar lube onto the polybush, should go in ok then.
failing that, use a jack under it to push it up if it doesnt have the adjusters on the bottom
Old May 29, 2010 | 01:10 PM
R5FORD's Avatar
R5FORD
Its got the adjuster screw on the side but il give it a go tomorrow with wd40 first
Old May 29, 2010 | 06:17 PM
Don't use WD40, use grease vastly better, sometimes the top mount metal gets pulled in a bit if the previous shock eye was just slightly shorter, I know they shouldn't be, I just put bottom on then jack up arm so it gets pushed into the hole, quick wiggle with s driver to align it, whack the bolt in, sometimes need to bash some metal bodywork under arch as a bit near on some and they scrape, just use a ball ended hammer on the body inner arch and the other hammer to hit the ball ended one.
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
truffleshuffle
Sep 10, 2015 09:35 PM
