Spraying my rs turbo wheels....
Old May 29, 2010 | 07:09 AM
Fordmad!'s Avatar
Fordmad!
Default Spraying my rs turbo wheels....
Hi, i am sprying my rs turbo wheels white soon and just want to see if my process is right....
Sand down and tape up tyre (done already)
Prime the wheel (2 cans for 4 wheels)
Lightly sand them when dry
Can of white paint on each (4 cans)
Laquer when dry (1 can for 4 wheels)
Is this right?
Old May 29, 2010 | 08:12 AM
LukeDaisley's Avatar
LukeDaisley
sounds about right. go for 5-6 light coats rather that heavy ones of colour. dont forget to tape up the valve stem.
Old May 29, 2010 | 08:11 PM
Fordmad!'s Avatar
Fordmad!
Light coats less likley to have paint runs then?
Old May 29, 2010 | 09:21 PM
Yes ,light enough to get a good coat but not too heavy to run
Old May 29, 2010 | 10:19 PM
matts1's Avatar
matts1
Light coat = less chance of running, but personally found taking a coat to the brink of running meant the laqure sat better than if it was to light which seemed to result in orange peel effect??
Guessing as Twins says, get enough on but not to much.
I also found clingfilm ideal for wrapping the tyres then tape the edges up by the rim and use a hair dryer to shrink the film to a snug fit. Quick and easy.
Old May 30, 2010 | 06:59 PM
LukeDaisley
i like the cling film idea i have a piece of cardboard with a round hole cut in it for that. I dust coat until the colour is right then 1 or 2 heavier coats to get the finish right then if needed flat and polish, give it a good panel wipe then lacquer to death for that deep deep shine.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
