Aeromotive big hp fuel pump and rs500 fuel rail for sale
As in title. Originally supplied and fitted by Reyland motorsport. Now no longer required due to a change of plans for our Escos. The car was speced out for 600bhp but now we are staying with 400 so we now only need the 044 item. It is supplied along with the aeroquip fittings which are -10 and -8. It was on the car for about 2 years but in that time only did about 2000 miles max. I believe this is the same type of pump used on the Reyland Escos so it is a very capable unit.
They are £350 inc vat from Reyland without the fittings.
Only £230 delivered within the Uk.
************NOW ONLY £220 DELIVERED***********
Cheers.
Adam.
07968545399 or saphycozzie@hotmail.com
AS IN TITLE. CANT BE TOO MANY OF THESE AVAILABLE NOWADAYS. ITS IN EXTREMLY GOOD CONDITION WITH A -6 FUEL INPUT TO FIT STRAIGHT TO AN AEROQUIP FUEL LINE. THIS IS NOT THE SAME AS A NORMAL FUEL RAIL AS IT HAS THE OUTPUT FITTING TO SUPPLY A SECOND RAIL AS FITTED ON ALL FACTORY RS500'S. THE FUEL FEED TO THE LOWER FUEL RAIL IS STILL BLANKED OFF SO THIS CAN BE USED AS A SINGLE RAIL IF NEEDED
£100 POSTED WITHIN THE UK
****************NOW ONLY £90******************
Adam.
************NOW ONLY £220 DELIVERED***********Cheers.
Adam.
****************NOW ONLY £90******************Adam.
kosienutter
31
Aug 22, 2015 09:55 AM
