Best oil for 400bhp saff
As above really,
Not had the car long and I'm unsure what grade/brand of oil is in it
I want to give it a good service on the weekend when I get home but dont want to use the wrong grade as I'm told if a car has ran semi, then you change to full synth, the car will just burn it off???
Sorry if this is a stupid question
..but theres ALOT of money went into the engine and I dont want to ruin it
Many thanks in advance
silkolene pro s 10/50
get it from oilman off here, you get a discount for being a pf member
http://www.opieoils.co.uk/
Cheers for that buddy...Just been on opie there and its quite cheap!
Dont know if it makes any difference but the engine has done less than 5k since extensive re-build
Thanks for the replys people!...are there pros and cons to using
the 2 different oils suggested?
I heard the silkolene (now Titan) is awsome
however I've heard the same about mobil 1 so just want a
comparison really
cheers
comparison really
cheers
Either oil is good, for my money it would be silkolene, engines don't burn oil unless there is a problem, but some forced induction engines like the yb/cossie can use oil, most of this passes past the turbo "seals" and is quite normal to lose a bit here if used very hard.
Cossies don't like thin oils, but as yours is that new you would most likely get away with a 40 weight oil, unless you use it hard in which case use a 50 weight such as the titan.
Im probably the only one to chemically have oils tested after Topspeed runs the oil that was still in Spec & lubricating 100% after such a test was Silkolene. Castrol RS was proved to useless & out of Spec within 2 runs. I use 5/40 for Topspeed running because that was best for the extreme test i put oils through for normal usage 10/50 . As stated its no longer called Silkolene but is the same oil.
Excellent! thanks for the replys everyone,
I've ordered the silkolene pro s 10/50 from opie, should be here by the weekend so i can get it lashed in the car
Thanks again everyone
deathrider666
Sep 28, 2015 06:12 PM
