Inside clearance in escos wheel
Old May 24, 2010 | 07:55 PM
Default Inside clearance in escos wheel
Hi,
Could some kind person measure the inside of a escos wheel, as toying with getting some, have new 330mm 6 pots to go on and helpful if I knew there was or not enough room to start with I need 253mm.
Thanks
Old May 24, 2010 | 11:35 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
go onto here Tabeth www.escortrsosworth.com the boys on there will defo know and also its a great site
Old May 25, 2010 | 07:37 AM
Hi Craig,
Thanks for that will have a nosey!!
Old May 25, 2010 | 06:02 PM
CRAIG HAYTER
you will defo like it on there matey
jessie_rs
62
Aug 6, 2019 09:27 PM
gcfcos
Sep 11, 2015 06:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
