Con Rods
Old May 23, 2010 | 04:01 PM
cossiedad's Avatar
cossiedad
Default Con Rods
Are there any differences between 2wd and 4wd sapphire con rods? And if so, can you fit 4wd versions in a standard 2wd engine?
Cheers all
Old May 23, 2010 | 05:09 PM
COLEYST200's Avatar
COLEYST200
they are different but you can put 4x4 rods on a 2wd just dont mix them
Old May 23, 2010 | 07:41 PM
cossiedad's Avatar
cossiedad
Thanks for that . So with that in mind, can I use 2wd pistons and crank with 4wd con rods? If so, which bearings do I need for crank to con rod, and con rod to piston ie 2wd, 4wd or are they the same?
stevecfrst1
Sep 30, 2015 05:18 AM
little bram
Sep 27, 2015 07:45 AM
S3an
Sep 26, 2015 11:39 PM
coscor86
Sep 20, 2015 01:21 PM
S3an
13
Sep 13, 2015 10:01 AM
