Best way to join the "trousers" part of exhaust ma
Old Jan 16, 2005 | 09:34 AM
boXXer's Avatar
boXXer
GASH!
Default Best way to join the "trousers" part of exhaust ma
Hiya, im gunna attemp to fix my exhaust leak today. Its leaking from just underneath the turbo, where the "trousers" part joins to the downpipe i think. There is no gasket in there, and its coming out the side. So what would be the best stuff to use to re-join it?
Diagram.....
Cheers,
Mike.
Old Jan 16, 2005 | 09:42 AM
Guinnless's Avatar
Guinnless
It may be damaged as it shouldn't leak at all. I doubt you'll find any gasket paste that will survive.
Old Jan 16, 2005 | 09:46 AM
Disabled Account's Avatar
Disabled Account
Mike,
No gaskets are used or needed, you've just got to make sure the
mating surfaces are perfectly flat and clean. Then, if possible use
NEW bolts/nuts that are evenly done up (progresively), and tight.
Old Jan 16, 2005 | 09:50 AM
Disabled Account
Some steel gaskets are available, but I will put up a
picture a bit later of what happens to them over time
Old Jan 16, 2005 | 09:54 AM
boXXer's Avatar
boXXer
GASH!
oh dear. sounds nasty. i will have to check that it is ok.
Mike
Old Jan 16, 2005 | 09:57 AM
Graceland's Avatar
Graceland
Team HOTHOT!
also refit using new locking nuts - normal nuts will vibrate loose over the space of a few miles
or use them washers with the locking tabs that fold onto normal nuts to lock them in place
Old Jan 16, 2005 | 09:59 AM
Dean Saff's Avatar
Dean Saff
maybe they could be machined(spell) skimed ?
Old Jan 16, 2005 | 10:16 AM
boXXer's Avatar
boXXer
GASH!
up. as i need to do it today. Cheers.
Old Jan 16, 2005 | 10:29 AM
Disabled Account
OK Mike,
This STEEL gasket was fitted to a small turbo Es Cossie,
running no more than 1.2 BAR boost (about 17 LBS/PSI)......
Because one of the nuts is very difficult to tighten up on
the 4x4 manifold, it will allways be the weak point
(unless it is correctlly/evenly tightened)........
This failure is NOT the fault of the steel gasket as such -
but you can see from the pics, the damage is the result of
incorrect fitting, it highlights the fact thar ALL 4 nuts/bolts need
to be done up correctly, and checked for tightness -
perhaps every 2k miles or so
Old Jan 16, 2005 | 11:19 AM
DazC's Avatar
DazC
get the 2 surfaces ground flat......
Old Jan 16, 2005 | 03:03 PM
boXXer's Avatar
boXXer
GASH!
ok, been outside all day, and found out it wasnt just that, that was leaking. The manifold gasket has also blown on number1, so i have stripped it all down, and its ready for a new gasket. Bollox.
Mike
Old Jan 16, 2005 | 03:14 PM
Smit's Avatar
Smit
The 60ft Launch King
your lucky it's not a 4b4 manifold they are a total coont to get off
Old Jan 16, 2005 | 03:26 PM
boXXer's Avatar
boXXer
GASH!
oh dear. Are they different then?
Mike.
Old Jan 16, 2005 | 08:04 PM
Smit's Avatar
Smit
yeah, tis a pain in the arse!
Old Jan 16, 2005 | 09:03 PM
tonyturbo's Avatar
tonyturbo
4x4 are a rite fookin nightmare.!!!!!!!!!!!!!!!!!!!!!!
155lee
Sep 6, 2016 11:10 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Bransby
Sep 14, 2015 08:54 PM
