focus, no drive
Old May 21, 2010 | 08:40 AM
n13los's Avatar
n13los
Default focus, no drive
sister's 1.8 petrol mk1 focus broke down last night, i went to have a look. there is no drive to the wheels, engine runs you can select gears (crunches into reverse) and there feels to be pressure in the clutch system (no leaks from the master cylinder).
i was thinking slave cylinder but now im not sure as the pedal returns.
anyone got any suggestions???
cheeRS Neil
Old May 21, 2010 | 08:11 PM
martysmartie's Avatar
martysmartie
If it were the slave cylinder you would not be able to select gear at all unless the engine was switched off, same applies for release bearing. It sounds like something to do with the assembly like a pressure plate fault.
Martin
Old May 22, 2010 | 08:05 AM
n13los's Avatar
n13los
centre of the clutch had been ripped out, fixed now.
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
Sep 3, 2015 10:49 AM
