cam belt
Old Jan 15, 2005 | 09:50 PM
moonstone mike's Avatar
moonstone mike
Default cam belt
Can anyone give me some pointers on changing my cam belt on my 3 door? i have changed cam belts before on my rs 2000 and my turbo but any tips on doing my cosworth would be great..
Old Jan 16, 2005 | 12:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hi Mike,
Try Here: https://passionford.com/forum/viewtopic.php?t=74383 with full colour pictures too
Old Jan 17, 2005 | 10:38 AM
moonstone mike
Top man
Old Jan 17, 2005 | 07:04 PM
Hectori's Avatar
Hectori
Timing gears-remove and install
Timing gears-remove and install2
Timing gears-remove and install3
Timing gears-remove and install4
Timing gears-remove and install5
there are instructions for changing timing belt. you must use 9.5-10.5 timing belt tension, for correct tension. for that, you need special tool.
use special care when locking timing belt tensioning pulley. when not assemblyed correctly, your engine might be damaged.
Old Jan 17, 2005 | 07:20 PM
moonstone mike
Thanks hectori i think you might of put me off doing it again just when i thoght i was gonna have a go myself
Old Jan 18, 2005 | 08:27 PM
Hectori's Avatar
Hectori
i think you could do it, but you must use caution, when installing belt. and belt tension meter is pretty cheap too. you could do it whitout that tension meter, but i dont advise it.
Old Jan 18, 2005 | 09:08 PM
phil robson's Avatar
phil robson
sorry to butt in, but can you tell me where i can get a tension meter
Old Jan 18, 2005 | 09:34 PM
Hectori's Avatar
Hectori
well, im not from there, but Burton power sales one, for example. 75£ if i remember right. maybe you can get one cheaper from car tool sellers.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
