Rover zr indicator fuse blowing
Old May 19, 2010 | 08:30 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default Rover zr indicator fuse blowing
A mate has a problem with a rover and just wondered if any one here noes any thing about them, Basicaly if indicating right the fuse blows and u loose ignition and the car cuts out, but is fine if indicating left
cheers
Old May 19, 2010 | 08:32 PM
ASHCOSSIE's Avatar
ASHCOSSIE
also when locking the car the indicators do light up so cant see it been a short, but i might be wrong
Old May 19, 2010 | 11:02 PM
martysmartie's Avatar
martysmartie
Could be as C/L gives indicator power elsewhere, it could be a short between switch and light. Do the hazards work?
Martin
Old May 20, 2010 | 08:57 PM
ASHCOSSIE's Avatar
ASHCOSSIE
na fuse blows with them as well
Old May 21, 2010 | 03:48 PM
martysmartie
Then it's almost certain the live for the right indicator has a leak to earth causing the short. Not sure on that car where alarm wiring is for indicators most likely to be spliced into the lives if it's not done by an electronic module so I would start at the indicator stalk and go from there.
Martin
AJC
Oct 1, 2015 06:47 PM
SMILER258
Sep 28, 2015 09:04 AM
Rammer46
Sep 18, 2015 08:31 AM
The Enigma
Sep 12, 2015 10:12 PM
