rear beam bushes
Old May 19, 2010 | 08:18 PM
wayne dowling's Avatar
wayne dowling
Default rear beam bushes
Hi are rear beam bushes easy to replace with the beam still on the car
And is there a special tool for putting them in with
thanks wayne
Old May 19, 2010 | 08:26 PM
RS SHAUN's Avatar
RS SHAUN
there not easy to get out mate, probably best to remove the beam!
cheers shaun
Old May 19, 2010 | 08:38 PM
opposite lock's Avatar
opposite lock
Beam off i,d say , iirc my pal used a press to get them out and replace new ones , good excuse to clean everything up at the same time if it needs it
Old May 19, 2010 | 10:36 PM
1223456's Avatar
1223456
Beam off, stripped, blasted, powder coated, polybushed, reassembled, refitted, never touch again
Old May 20, 2010 | 09:47 AM
grcossie's Avatar
grcossie
Yes there is a special tool, and you don`t need to take the beam off, we never do that on any Sierra, Scorpio or Escos at work. But if you want to do more, like autoflock say, then take it off
Old May 20, 2010 | 04:21 PM
I made the tool I use about 10 years ago, took and hour to make out of some 3/4" box section, this installs as well as removes with zero damage, with beam on car, just undo side you are doing place a block of wood about 3" thick between body and beam where needed for space, use tool, tkaes about 1 minute to get out, and about 10-15 to get in as have to do slowly and it is squashed in.
Old May 20, 2010 | 04:34 PM
grcossie's Avatar
grcossie
We also use wood box sometimes, but we have the original tool to use for it also
Old May 20, 2010 | 04:38 PM
Turbosimpsons's Avatar
Turbosimpsons
piece of cake with beam on. no special tools needed. just large socket and block of wood. i did some yesterday
Old May 21, 2010 | 08:02 AM
Turbosimpsons
pop it down to turbosystems. don't think he will charge you to much to fit them for you.
Old May 23, 2010 | 10:44 PM
wayne dowling
cheers lads bought another beem as mine is bent so will put them in the new beem befour i put it on
thanks wayne
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
