boost pressure in different gears
Old May 19, 2010 | 08:07 PM
sundera86's Avatar
sundera86
Default boost pressure in different gears
is it normal my boost pressure to be lower at 1st an second gear?
at second gear i have peak pressure 1,4 bar and in high rpm drop to 1,1 bar
could you tell me what is your pressure at different gears
my is
1st 1,3 peak - 1 bar hold
2 - 1,4peak - 1,1 hold
3 - 1,5peak - 1,2 hold
4 - same
5 - same
Old May 20, 2010 | 06:45 AM
oldford's Avatar
oldford
Pretty normal, seen it on many vehicles.
Old May 20, 2010 | 07:08 AM
cossie604's Avatar
cossie604
Less engine load in the lower gears.
Old May 20, 2010 | 04:23 PM
Looks pretty normal for those using chips with peak and hold type thing, mine just does similar but without any peaks.
Old May 23, 2010 | 11:12 PM
MalZon's Avatar
MalZon
+1
//Jonas
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
