Metering unit
Old May 19, 2010 | 11:12 AM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Default Metering unit
Hello folks
How do you know when the fuel metering unit is knackered?
Is there some signs when its on its way out?
Just wondering as a local garage to me was saying about changing it and a fuel relay that sits in the dash.
I said that the car pops well on over rev and that the battery was being drained by something and he mentioned those 2 things
Help please if you can
Old May 19, 2010 | 04:57 PM
The metering unit either works or not, it's simply a flap that moves in repsonse to air movement, to which it has a valve connected inside which alters the fuel at the same time as the air, ie more air more fuel, the flaps sometimes stick, but normally a ring of gunge around the plate inside, carb cleaner soon sorts it.
This is not remotely connected to any battery draining issue though.
Old May 19, 2010 | 07:11 PM
eoeumc's Avatar
eoeumc
Thanks Tabetha
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
