Anyone have back to back comparisons of Cosworth downpips compaired to Escort ones?
Old May 17, 2010 | 09:21 AM
muz's Avatar
muz
Wye Valley Hardcore
Default Anyone have back to back comparisons of Cosworth downpips compaired to Escort ones?
I'm about to fit my T34 .60/.48 with an ERST ehaust housing but I want to know, does anyone actaully have any back to back tests to show the differences between using the Cosworth .48 exhaust housing and downpipe and an ERST .48 housing and downpipe?
I know the Cosworth set up is supposed to be less restrictive etc and worth fitting but just how much better is it?
Jano gave me some good advice about it yesterday, but if we are talking a big imporvmeent I would do the extra work to fit one.
Old May 18, 2010 | 10:27 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Muz the system i sold off the Black Fezzy at FIT was cossie setup, speak to creator and ask him to take a pic of it as i sent it to his mate. He tooks pics of it before he was going to fit next to his FRST downpipe which is very similar to T3.
Old May 18, 2010 | 10:57 AM
muz's Avatar
muz
Wye Valley Hardcore
I'll PM Danny then Jano. I did take on board what you said at FITP, but the chaps offering to swap the housings free, and if with my spec I can gain say 10LBS of tourque by swapping them then it would be worth it. Fabricating a downpipe is no problem.
Old May 18, 2010 | 12:27 PM
Versus_Creations
Ask me a question!
You will need a flange and clamp from a cossie downpipe mate but other than that its pretty easy to make a downpipe up. The other mod will be an actuator bracket as there is none off the shelf that will fit.
Old May 19, 2010 | 07:25 AM
creator's Avatar
creator
ill go take some pics today mate ill send them over this evening
Old May 19, 2010 | 07:42 AM
muz's Avatar
muz
Wye Valley Hardcore
I'm on holiday as from lunchtime today so no rush, but if you could get sone over that would be great Danny.
Old May 19, 2010 | 10:20 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if you click on my link in my signature, you can see how i made a down pipe and bracket for the actutaor to fit in an xr2 engine bay.
i think it flows better and even with a 0.48 housing it seems to spool about the same as the escort standard t3 did on the 0.36 housing.
no factual/evidential comparrisons though.
Old May 19, 2010 | 10:21 PM
little bram's Avatar
little bram
muz me and my brother made abit of exhaust so i could use a cosworth exh housing and the standard rs down pipe can you not do that. pic for you mate
Old May 20, 2010 | 09:30 AM
Versus_Creations
Ask me a question!
little bram thats quite nice.
Only if you want to keep the std exhaust in one bit but dont really get the point other than being able to fit other systems or change etc.. Would probly be better in one welded piece tho.
Old May 27, 2010 | 06:57 PM
muz's Avatar
muz
Wye Valley Hardcore
Ah that looks good Bram. I'll just buy a cossie downpipe and bastardize it to my system. Cosworth housing is being fitted as we speak.
James Porter
Aug 26, 2015 10:51 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
