pic of my 24v capri...
John, my advice is as follows:
1. befriend a good autosparky.
2. use the t5 box.
3. ditch the EGR and cats.
4. make sure you put a massive air filter on it or it'll hunt like mad and drive like you're sat inside an accordion.
i'll dig some more pics out.
2. use the t5 box.
but im getting all the running gear ready for the convertion
mate ive just bought a scorpio cosworth with the bob engine but you dont see many use it........... is it a different engine or something???
love your motor mate and want to build my own but using a mk1 shell
the engine is smooth, lots of lazy torque at the bottom and revs strongly. bloody loud tho. speed wise it feels similar to an s14 200sx up to about 130. above that it's too unstable as i haven't done the brakes yet!
i think the BOB gets used less because it's harder to rewire. some people put the BOB cams in the BOA though.
that 3 door looks bloody good. google the top boss blue steel one, should be good for inspiration!
it does sound nice i had a custom stainless fitted to it,hope to get it on the road by end of the summer,i have fitted electric fans to it but cant find the sensor to plug them in any ideas where it is......
i used a dohc sierra rad and fans, was advised this is the right one to use. i bought an adjustable switch/temp sensor like the ones you get for kenlowes (the little brown box in front of the washer bottle) and had it wired in with a relay. i also had an override switch mounted to the dashto bring the fans in manually if i need to. The engine can get warm if it's driven hard then gets stuck in traffic, so it's nice to have the choice.
myns very smooth and very reliable. i would like abit more power but i do use it in my daily (p100) off the line its fine but i have 4x4.
i bought an xr4x4 and used everything off that. engine is VERY LOUD! im running like 4 boxes and i cant track day it without sticking a stupid extra box on.
get some more pics up of the capri :P
Yes i know a fair bit.me and my mate done all the work on ours ourselves.I done the wireing,we're now in the process of upgradeing the gearbox to mt75 as the type 9 blew to pieces with the nitrous.Any thing you need to know just ask.
definitely use the t5 box. it used to be really tricky to make it fit, but there are lots of conversion kits, bellhousings, etc. did mine a few years ago and there was a lot of head scratching, but nowadays it's so straightforward you'd be mad not to.
Yeah that's what I'm doin going to use bob engine with t5 box xr4x4 rear beam 4 pot brakes on front one piece prop scorpio lsd then ill think about a turbo convcertion try and get about 360+ bhp in my saph seen loads with superchargers but they are top money
