boost pressure drops in high rpm
Old May 16, 2010 | 02:12 PM
sundera86's Avatar
sundera86
Default boost pressure drops in high rpm
before 1 month i drove my cossy 4x4 and boost pressure was 1,2bar overboost and 1 bar in high rpm !
today i drove the car and the boost pressure drops from 1,2 bar to 0,8 bar in high rpm ?
please help
Old May 16, 2010 | 02:31 PM
martynhomer01's Avatar
martynhomer01
could just be an inacuracy in the guage mate?
Old May 16, 2010 | 02:43 PM
sundera86's Avatar
sundera86
i dont think so, the car is slower, i drive without amal valve, i am with manual boost controler, should i fix the problem with bleed some air from boost controler?
Old May 17, 2010 | 03:46 PM
sundera86's Avatar
sundera86
how can i understand that my actuator work properly. Some test for actuator ?
Old May 17, 2010 | 11:11 PM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
sounds like a classic weak actuator to me, or maybe a leak in the vac hoses connecting to the actuator, try looking at the latter 1st before you condemn the actuator
Old May 18, 2010 | 04:12 PM
sundera86's Avatar
sundera86
if my actuator is bad i think that peak pressure should drop also. Why my pressure drops dramaticly in high rpms? My peak pressure is ok - 1,3 bar but in high rpms it drop to 1 bar sometimes to 0,9 bar. Is it possible actuator go wrong only in high rpm
Old May 18, 2010 | 05:09 PM
NEILNATO's Avatar
NEILNATO
basically at high boost if you have a weak actuator spring the force of the boost will push the rod out alot quicker resulting in the wategate opening too early at high revs, but will stay closed longer lower down the rev range which will make the issues you are describing, another possible cause which i have came across in the past was the cam timeing was out so at high revs and as it was quite a fierce cam and it was keeping the exhaust valves open for too long hence loss in power, this was on an rs turbo which only has one camshaft but im sure the same would happen on the twincam YB. just a thought
Old May 19, 2010 | 06:17 AM
sundera86's Avatar
sundera86
is it possible the problem is dump valve ?
how can a check dump valve ?
Old May 19, 2010 | 06:43 AM
ST Turbo's Avatar
ST Turbo
Take the dump valve out completely, and see if it still drops off and loses boost. But is most likely to be the actuator as everyone is saying!
Old May 19, 2010 | 06:50 AM
sundera86's Avatar
sundera86
ok it is maybe actuator, but why when i bleed some air from boost conntrol peak pressure gains perfect and in high rpms there is dramatic boost drop.
I think if the problem is actuator it should be problems with peak pressure also ! Am i right ?
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
