Sapphire - 22 mm Rear Anti Roll Bar
Old May 16, 2010 | 06:31 AM
BJAS's Avatar
BJAS
Default Sapphire - 22 mm Rear Anti Roll Bar
I had been after a 22 mm RARB for some time; without success. So rather than wait any longer, we removed the rear bar from another Sapphire and had it copied in 22 mm. Here is the finished bar. Turned out pretty well.
Old May 16, 2010 | 08:29 AM
Mike1's Avatar
Mike1
Looks a good copy - how much did it cost to have made?
Luckily for us in UK, we can still pick up Scorpio/Escort Cosworth ones/Saph Cos 4x4 items relatively easily but i guess they must be extremely rare in Oz
Old May 16, 2010 | 04:51 PM
I would have made it adjustable at the same time, what material did you use ?
Old May 17, 2010 | 08:20 AM
BJAS's Avatar
BJAS
They are non-existent here.
Didn't cost much at all; very cheap really.
Old May 17, 2010 | 08:39 AM
KSA-Cossie's Avatar
KSA-Cossie
got an escos one to fit to my saph
Old May 17, 2010 | 08:42 AM
BJAS's Avatar
BJAS
I'll be interested to see what it does to the handling. Is it necessary to change the front set-up with the 22 mm bar on the rear?
Old May 17, 2010 | 10:10 AM
Mike1's Avatar
Mike1
The question though is what to change it to? No readily available OE thicker 2wd replacement I would guess for you living in Oz. Comp struts and a 909 set-up? Having said that looks like you have got someone handy to fabricate a thicker front one if you deem it necessary to get more front roll stiffness.
Old May 17, 2010 | 10:32 AM
R5FORD's Avatar
R5FORD
why not just get one sent over? seems alot of hassle for a minor thing tbh but does look good
Old May 17, 2010 | 06:22 PM
I got a 22mm adjustable one on the rear of my sapphy, you will need to tweak the front rear damp rate to get best, front arb is plenty stiff enough, may just need softening slightly on the front dampers.
The high speed stability in particular is amazingly improved with the 22mm rear arb.
Old May 17, 2010 | 06:47 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine are medium front and hard back,any god tabs ?
Old May 17, 2010 | 06:54 PM
Best way is try and see what suits you, and your driving style, don't go too stiff on dampers to try and combat roll though, will be very odd at the limit, I've intentionally left a little roll on mine, as I want grip, will just slide if too stiff.
Old May 17, 2010 | 11:07 PM
BJAS's Avatar
BJAS
I have a set of Konis and Bayjoo fast road springs that will go on the same time. Hopefully it will all work well together .
Old May 18, 2010 | 12:35 AM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
to be fair i use a 22mm rear ARB combined with standard spec dampers and eibach springs, the car rides just perfect i think, not too stiff or too soppy
Old May 18, 2010 | 06:55 AM
Mike1's Avatar
Mike1
I think they will chap
Old May 18, 2010 | 05:55 PM
AS above will be fine, a good set up.
SmudgerByName
52
Jul 28, 2016 06:14 PM
turbotrev
14
Sep 6, 2015 10:27 AM
TrevCos
Aug 17, 2015 09:08 PM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
