Focus Rs mk 1 Conrods. Where can i buy them???
Old May 14, 2010 | 08:58 PM
Bartheez's Avatar
Bartheez
Default Focus Rs mk 1 Conrods. Where can i buy them???
I am looking for a set of standard Focus Rs conrods. - With 22 mm guide-pinhole for the pistons. This is for my Escort Rs Turbo Zvh project.
I have already purchased a set of brand new Focus Rs pistons. But i bought them unknowing that the guide pin is 3 mm bigger on the Focus Rs pistons than on the standard Zetec rods...
Therefore i need a set of Focus Rs conrods.
Where can i buy a set of standard rods? Used with low milage or brand new ...
I dont need ugraded rods. I wont get over 300 bhp anyways
Hope you can help me out? ...
Best Regards - Kasper Norup Andersen - Denmark
Old May 18, 2010 | 10:07 PM
Bartheez's Avatar
Bartheez
Uppp
Old May 19, 2010 | 05:05 PM
I'd look on ebay, I saw some brand new nice H section forged rods by a company going for Ł180 buy it now brand new, they defo did them for scoobs, cossie/zetec and most likely FRS ?
ebay.co.uk that is.
Old May 19, 2010 | 05:20 PM
ST Turbo's Avatar
ST Turbo
ebay.co.uk that is.
Theres are company on egay where they sell eagle rods i think (im sure these are the ones your are talking about ^^^) However they do two different types, one with larger bolts and one with smaller con rod bolts! You want the ones with larger bolts!
Old May 19, 2010 | 11:27 PM
Bartheez's Avatar
Bartheez
Neither of those unfortunalely :-(...
Eagle rods arent made for the Focus Rs. Only Zetec turbo (With 19 mm guide-pin hole)
Old May 19, 2010 | 11:30 PM
Bartheez's Avatar
Bartheez
Ooops... I miscalculated - 20 mm. guide-pin hole. But still far from 22 mm :-(
Old May 19, 2010 | 11:38 PM
pdfbt40's Avatar
pdfbt40
I'm afraid your going to have to hope for Ebay or RSOC....
As your probably aware, the FRS conrods/pistons were unique dimensions only used on that engine.
There are 3 other dimension sets for Zetec-E engines:
1) Silvertop
2) Blacktop
3) American Blacktop
All have different pin/rod length/piston height dimensions.
Martin
Old May 20, 2010 | 04:45 PM
If any of the other rods are the same length maybe bush the pistons might be cheaper ?
Old May 20, 2010 | 04:53 PM
ST Turbo's Avatar
ST Turbo
Didnt know there was a difference in the holes! I thought the only difference between a blacktop and Focus RS lump was basically the forged pistons!
How sure are you? When i was buying my rods, im sure there was no difference in part no's between the two engines. Unless there is no difference if forged rods and forged pistons have a specific size gudgeon pin!
Old May 20, 2010 | 05:13 PM
pdfbt40's Avatar
pdfbt40
100%
Rod Pin
Silvertop 136.14mm 20.64mm
Blacktop 140.84mm 19.00mm
FRS 137.00mm 22.00mm
USA 139.19mm 20.00mm
The BE to piston crown is the same for each set.
I'm not sure what dimensions the Cosworth 'WRC' rods and pistons were made to, but as they are virtually impossible to find....
Steel rods from America (Eagle, Crower) are to the US dimensions, but supplies from stock (and pistons) are reducing, after all the engine is obsolete.
Martin
Old May 20, 2010 | 05:14 PM
ST Turbo's Avatar
ST Turbo
hairy muff, learn something new everyday!
Old May 20, 2010 | 05:31 PM
XRT_si's Avatar
XRT_si
That explains something! A friend had a set of steel rods with a massive 22mm gudgeon pin andwe couldn't work out what it was for!
Old May 20, 2010 | 10:28 PM
Bartheez's Avatar
Bartheez
Is your friend still in possession of theese rods???
Old May 21, 2010 | 12:42 AM
pdfbt40's Avatar
pdfbt40
Could see that one coming.
Martin
Old May 24, 2010 | 09:18 AM
Bartheez's Avatar
Bartheez
Default :-)
Uppppp
Old Oct 23, 2010 | 10:12 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
I have a new set of rods with bolts, also Pistons dark black with valve cutouts and coated sides. (Not for sale)
But would like to see some WRC rods if anyone has pics.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
gavt123
Sep 5, 2015 10:03 AM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
