Earth strap locations - S2 Turbo
Hello all, can someone tell me the locations of all the earth straps in the engine bay where they connect from , to.
I know a couple, from the bonnet to the lifting eye and gearbox where are the others??
Also what size terminals to make new ones??
CheeRS!
CheeRS!
no it should be bonnet to screw on inner wing just under hinge, from sus turret just above engine mount to lifting eye on inlet, from battery to starter via one of the starter to gearbox bolts and lastly passenger inner wing by fuel accumulator to spade terminal about 2 inches to right and 1 inch down of the clutch lever on box
Matt Baxter
Sep 16, 2015 08:30 PM
