which oil???
Old May 11, 2010 | 10:23 PM
scratter's Avatar
scratter
Default which oil???
i have just bought some 10w40 castrol gtx for my rst will this be a good enough oil? also what oil do i need for my gearbox?
dan
Old May 12, 2010 | 06:15 AM
ROB7656's Avatar
ROB7656
75/90 gear box oil. 10 /40 should be ok. i would recommend 15/50 mobil1 motorsport!
Old May 12, 2010 | 06:39 AM
rs_turbo_tony's Avatar
rs_turbo_tony
wots history of engine try use same oil has car has always had. if you dont know i would use lucas synthetic 20/50 race oil or 10/60 lucas has additives to stop metal to metal contact and is very good oil compared to most off the shelf oils and for your gear box lucas do 75/90 sythetic gear oil and have read up good for rs turbo gear box using lsd hope this helps
Old May 12, 2010 | 07:01 AM
Fordmad!'s Avatar
Fordmad!
So which oil would you recommend i use on my XR£i 1990 EFI, would it be the same as the rs turbo, Halfords recommend 5w30 partly synthetic? Any advice would be good thanks!
Old May 12, 2010 | 04:09 PM
scratter's Avatar
scratter
thanks peeps
Old May 12, 2010 | 04:45 PM
rs_turbo_tony
same as above would be good enough (added protection )
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
