Cossie running REALLY rich
Old May 11, 2010 | 05:49 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Default Cossie running REALLY rich
It stinks of petrol, it's drinking the stuff, there's black soot all over the back end. Is there anything obvious I can check? 4x4 red top greens t34 etc.
Old May 11, 2010 | 06:08 PM
CTS,
Old May 11, 2010 | 06:39 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Originally Posted by tabetha
CTS,
I do have a new one of those around somewhere, but they ain't positioned easy to get to are they?
Old May 11, 2010 | 06:55 PM
bad boy rs's Avatar
bad boy rs
also air charge, map and air leaks. Got this on mine aswell at the mo but cant cure it
Old May 11, 2010 | 06:56 PM
Not the easiest thing to get to, no.
Some do it from underside on ramps etc, I do it from the top using a deep socket, think it's 19mm ?, then a short extension on a 1/2" rachet, more doen by feel than anything else, but only takes a few mins when stuck in, but massive difference if it is that.
Old May 11, 2010 | 07:33 PM
RobertM's Avatar
RobertM
Also check your fuelpressureregulator, could be the membrane has ruptured.
Check by pulling off small hose that goes to inletplenum, no fuel must come out of regulator.
Robert
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
The Enigma
23
Aug 31, 2015 06:21 PM
kosienutter
31
Aug 22, 2015 09:55 AM
41
Aug 7, 2015 08:58 PM
