Mk4 XR3I EFI Running Lean?
Old May 11, 2010 | 03:23 PM
jedi0_3's Avatar
jedi0_3
Default Mk4 XR3I EFI Running Lean?
Following MOT my CO is 0.211 & HC=1037
I have been advised that the CO is too low probably pushing the HC up.
What could cause lean running EFI CVH and what are the possible fixes?
Thanks
Old May 11, 2010 | 07:53 PM
MarkN's Avatar
MarkN
Should be running 1.25%. You need to adjust the CO adjustment pot
Old May 11, 2010 | 10:34 PM
jedi0_3's Avatar
jedi0_3
Can I do it myself or is it a garage job?
Old May 11, 2010 | 10:36 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
you can do it you self. a small flat screw near the "edis" iirc
Old May 12, 2010 | 07:16 AM
jedi0_3's Avatar
jedi0_3
What way do you turn it?
Old May 12, 2010 | 07:49 AM
Turbophille's Avatar
Turbophille
Anti-clockwise. You can hear revs rise and fall as it moves between rich and lean. get it at the mid point where revs drop off. You still need to have it checked, so its worth giving your local garage a drink just to get a reading. Mine has never been far out. hope this helps
Old May 12, 2010 | 08:44 PM
jedi0_3's Avatar
jedi0_3
Thanks guys for all of the help, I will try the adjustment myself then Turbophille thanks!
Loving the Escort Chavriolet-quality!
xrmalin
Sep 13, 2015 06:52 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
bigryrs
Sep 7, 2015 06:45 PM
fuzzy
Sep 4, 2015 10:11 PM
