Engine management light on
Old May 11, 2010 | 08:39 AM
rs kyle's Avatar
rs kyle
Exclamation Engine management light on
The old man went out in his 3 door the other day and on acceleration around 3-4000rpm the engine keeps cutting out and the engine management light comes on. If you turn the ignition off and restart the engine the light goes out and resets itself but as soon as you accelerate again the fault re occurs. The engine hasnt long been rebuilt so he is just trying to run it in ready for a set up.
can anyone help? thanks kyle
Old May 11, 2010 | 10:32 AM
oldford's Avatar
oldford
Fastest way is to get the codes read. You would need a Led- or Star-tester.
It's normal that all errors reset when you turn the ignition off. So, connect tester, do a run and read the fault code(s).
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
