Converting lifters
Old May 10, 2010 | 02:52 PM
GTi_Tom's Avatar
GTi_Tom
Default Converting lifters
I know about converting to solid lifters from hydraulic but it is possible to go the other way and fit hydraulic lifters in place of solid lifters?
Old May 10, 2010 | 05:41 PM
Only if the cylinder head has a oilway in the bore hole of each tappet supplying pressurised oil.
Old May 10, 2010 | 06:14 PM
paulj's Avatar
paulj
yeah this has been done on my blacktop zetec turbo head,
cheers paul
Old May 11, 2010 | 11:03 AM
Sp3no's Avatar
Sp3no
What are the advantages of fitting hydraulic lifters, apart from being quieter
Old May 11, 2010 | 05:35 PM
GTi_Tom's Avatar
GTi_Tom
Not having to check valve clearance and shim all the time, convenience really. The downside is they don't cope with high rpms
Old May 11, 2010 | 06:20 PM
They're not always quiet, when they go wrong!!
I am going solid/shim on my rebuild as sick of clickety click all the time, can't say I've noticed any particular noise from solid ones adjusted correctly, and only found on previous cars about every 25,000 might need a different £2 shim, mnost you can do swappsies with anyway for other tappets on the same engine.
mondeomark
Sep 28, 2015 06:28 AM
jonnyenglish
Sep 21, 2015 07:31 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
