help. what ecu???
Old May 9, 2010 | 10:44 PM
alexno1dj's Avatar
alexno1dj
Default help. what ecu???
Ok putting a 1.8 130 spec zetec in my escort 1.6. Im keeping loom, sensors etc. but what ecu should i use? will it work on 1.6 ecu? cheers
Old May 10, 2010 | 06:54 AM
oldford's Avatar
oldford
No, you need the ecu from the donor car or use an aftermarket ecu.
Old May 10, 2010 | 07:28 AM
rs220bhp's Avatar
rs220bhp
1.6 ecu will work, wont be much cop though as you ideally need a 130 spec one, depends what kind of loom you have, it its internal edis at the moment you need a CULT ecu and if its external edis you want a 2FBC or 2FDC ecu from a rs1800 or mk5 escort xr3i. Depending on what year it is, if you have PATS on your car this will limit your chioces further without a lot more wiring
Old May 10, 2010 | 09:03 AM
alexno1dj's Avatar
alexno1dj
Ok as far as im aware it does have PATS, its a 1998 escort.
How will i know if it has external EDIS?
Can the 1.6 ecu be re-mapped?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
muzzman1
Sep 30, 2015 08:59 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
