Any diesel experts out there? 1.8 fiesta
Old May 9, 2010 | 07:43 PM
timster's Avatar
timster
Default Any diesel experts out there? 1.8 fiesta
Bought a mk3 fiesta diesel as a runabout,goes okay and does decent mpg but smokes blue when accelerating,read that it could be the pump worn and needs adjusting,anyone done this?cheers
Old May 9, 2010 | 09:10 PM
Austin101's Avatar
Austin101
Your talkin sh** now
Injectors maybe
Old May 9, 2010 | 10:10 PM
forevaford's Avatar
forevaford
burning oil? they are usually bomb proof lol
Old May 10, 2010 | 05:52 PM
Sounds like oil, as in engine oil, but these are usually long lasting, rattly as f**k but long lasting, it can also be caused by a slight amount of petrol in the diesel, if you are talking very light blueish smoke, that gets worse under acceleration ?
I would in any even drain off the water from the filter head and check the diaphragm in the filter head has not gone porous, very very common.
Old May 10, 2010 | 07:16 PM
timster's Avatar
timster
do you mean the fuel filter tabbs?its the later type with no manual primer pump just two pipes in/out of filter
Old May 11, 2010 | 06:26 PM
Yes did mean fuel filter head.
Old May 12, 2010 | 08:27 PM
R4N SS's Avatar
R4N SS
if its the pump there is a place in wales i know of that can do it relatively cheap
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
DavidK
Sep 27, 2015 02:55 PM
