can i make s2 turbo an xr3 again
Old May 8, 2010 | 03:47 PM
gaz.123's Avatar
gaz.123
Post can i make s2 turbo an xr3 again
I have an xr3i which was once turbo converted. It has been sitting in my garage for the past 6 or so years, ever since i blew the turbo unit on the way to fitp. As i have no money to repair, i was wondering if anyone could advise if it is possible to swap the turbo charged engine [zvh] for an xr mfi engine without changing the looms. Would it run??? I just want to drive my car. its been missed.
Old May 8, 2010 | 09:28 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
i would say loom would need changing too
Old May 8, 2010 | 09:47 PM
dangerousbrian's Avatar
dangerousbrian
would it not work if you just took the turbo off and changed the exhaust?
Old May 8, 2010 | 09:56 PM
phil_rs's Avatar
phil_rs
yam yammer
If it's just the turbo which has gone it's gonna be far easier and probably just as cheap to replace it than convert back. As said you could just remove the turbo and replace the exhaust with a xr3i item. A friend did this and it ran fine
Old May 8, 2010 | 10:04 PM
jonny s2's Avatar
jonny s2
id say it would be just as cheap to replace the turbo pal, unless the engine is naffed etc.....
Old May 8, 2010 | 10:25 PM
studabear's Avatar
studabear
think how miserable it will be to drive with much less power
Old May 8, 2010 | 10:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It will work if you just loose the turbo and change the exhaust but then you have a low comp NA lump! lol
Old May 9, 2010 | 07:53 AM
gaz.123's Avatar
gaz.123
didnt realise i could just lose the turbo will try it i think. Just need to get a set of head bolts and gasket as i swapped the head with a mate. I only asked as money is tight [bloody kids are expensive] and my missus doesnt really want it on the road, so i have to be as economical as possible to keep her sweet lol. I have acess to a writ off xr i was just gonna swap the engine but after reading what people have suggested i will try just the exhaust instead. This is my first post and already i am loving thess forums thankyou everyone who has made a suggestion. will let you kn ow how it goes.
Old May 9, 2010 | 08:02 AM
gaz.123's Avatar
gaz.123
im just wanting to drive my mk4 again dont care how fast it is,its been too long.
Old May 9, 2010 | 08:55 AM
rs_turbo_tony's Avatar
rs_turbo_tony
take turbo off put exhaust on .and then send turbo off for recon. theres a company on ebay based in blackpool. cost around 140 quid if shafts ok in turbo my mate used them and they seem to be pretty good
Wilsfoci
15
Mar 30, 2016 10:26 PM
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
rs_turbo_ant
Aug 8, 2015 11:11 AM
