plenum spacer
Old May 8, 2010 | 10:29 AM
davecosworth's Avatar
davecosworth
IM BACK
Default plenum spacer
has any one seen any improvement from useing one bit worried about running 2x gaskets as its anther one to leak maybe get it o rings or welded on also what depth 10mm or 14mm also what lenght bolts have you used ?
Old May 8, 2010 | 04:51 PM
bad boy rs's Avatar
bad boy rs
got a 14mm on mine, use cometic gaskets and you wont have a problem
Old May 8, 2010 | 04:53 PM
benporter's Avatar
benporter
i dont know the pros a and cons , but i do know Karl norris said to take it off a car what was getting mapped for 500bhp
Old May 8, 2010 | 04:57 PM
bad boy rs's Avatar
bad boy rs
whys that mate ?
Old May 8, 2010 | 04:59 PM
benporter's Avatar
benporter
he said you didn't need it because its the elbow what is restrictive
Old May 8, 2010 | 05:01 PM
bad boy rs's Avatar
bad boy rs
on a 2wd or 4x4 ?
benporter's Avatar
benporter
4x4
Old May 8, 2010 | 05:03 PM
bad boy rs's Avatar
bad boy rs
oh right didnt realise the 4x4 one was that restrictive, so its only slightly better flowing than a 2wd
Old May 8, 2010 | 05:54 PM
gibbo frst's Avatar
gibbo frst
i drilled the threads out on the manifold then used longer bolts to nut and bolt it.. seems to clamp it better and havent had any leaks on mine... dont get the 10mm one as its a pain to fit the fuel rail back on.. think the 14 mm is the one that just locates the rail the other side of the lugs..
Old May 8, 2010 | 08:31 PM
fatmike's Avatar
fatmike
sweedish plenum seems to be a good route to go. The elbow is the problem on the standards. The sweedish plenum I have has the spacer actually incorparated and welded into the unit. I personally like the look of the mike rainbird plenum. Is quite a reasonable price and is good up to something like 700bhp. It is what I will probably buying before getting car set up.
But at the end of the day, you could say what is the point on having a decent flowing inlet if you have standard head with no work done to that... It will still be restrictive after if goes through the plenum.
Old May 8, 2010 | 11:09 PM
boost mad's Avatar
boost mad
where can you get the 14mm ones from ?
Old May 9, 2010 | 04:09 PM
davecosworth
IM BACK
ok thanks guys i might just have some tubes welded from the elbow to 1 and 4 end to even out flow not sure yet just polished the plenum inside and port matched it.
Old May 10, 2010 | 04:16 PM
BRAMMER's Avatar
BRAMMER
Got a 17mm spacer on my 4x4 manifold, straight on with a pair of cometic gaskets
Old May 10, 2010 | 07:32 PM
WongRS's Avatar
WongRS
would u need to change the chip if you fitted one do you think?
Old May 10, 2010 | 08:38 PM
davecosworth
IM BACK
am still finalising my map at the moment
Old May 11, 2010 | 03:57 PM
ASHCOSSIE's Avatar
ASHCOSSIE
sure i saw before some one had cut and welded the standard elbow to aid flow, any ideas who to do this
Old May 11, 2010 | 04:35 PM
gibbo frst's Avatar
gibbo frst
i had mine done by a local place to me.. seems to work...
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
