Pic request: Hyd clutch fitting
Old May 7, 2010 | 08:52 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Default Pic request: Hyd clutch fitting
anyone got pics of how they fitted thier master cylinders and reservoirs?
Old May 8, 2010 | 01:09 PM
The master cyl just fits on the bulkhead, with a reinforcing plaet the other side(inside).
I can get some piccies of roosie's but that's a pedal box, the reservoir is normally remote and joined to the master cyl by a pipe, leading from behind the firewall where most put there's.
If you want me to get some piccies pm me your email as I can't host piccies.
Old May 8, 2010 | 01:27 PM
rs_turbo_tony's Avatar
rs_turbo_tony
i have got magazine with step by step instructions by reylands give us your email adress and will scan and send to you
Old May 8, 2010 | 01:55 PM
Sonic Boom's Avatar
Sonic Boom
Tony I wouldn't mind a copy of that too mate.
Cheers Rich
Old May 8, 2010 | 04:01 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
cheers for the replys, guys
tony, my email is evil-dave@hotmail.co.uk
cheers bud
Old May 8, 2010 | 09:52 PM
rs_turbo_tony
Default hydro clutch
here you go guys hope it helps cheers
Old May 8, 2010 | 09:54 PM
rs_turbo_tony
Old May 9, 2010 | 12:55 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
legend!! cheers tony!
Old May 9, 2010 | 09:00 AM
rs_turbo_tony
Default first page here
Old May 9, 2010 | 12:12 PM
If you source the bits yourself, you can do the lot for well under £100 using new parts, something to bear in mind.
Old May 9, 2010 | 01:15 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
lol, shame i already bought the kit, but instructions were missing. was less than half the price of buying it direct, though
Old May 9, 2010 | 03:19 PM
I have used in the past a sherpa V8 master cyl with remote reservoir, and slave cyl from same, but the BMW E36 slave can be used and is a good fit around £15 new from the bay on a good week, just get a master with similar or slightly more bore diametre, so long as the push on the master is enough for the stroke of the slave it will work, you can also set your biting point where you like, the bit of metal re-inforcement that IS needed can be made easy enough, with some 3mm sheet mild steel, then measure and get pipe made to suit.
I did a conversion on my dads xr4i around 7-8 years ago, and apart from having to renew the master cyl seals once has been faultless.
This is without doubt the best thing mod wise you can do to a cossie, esp if uprated clutch, the clutch will become so light and easy but totally progressive so really good for any snatchy clutches, mines a bit like that and with the cable sticking etc as it wears through the nylon inner and starts jamming up it can be a bit awkward, but love it when I need to use the 4i with hydraulic!!
Old May 9, 2010 | 04:05 PM
KENNY G's Avatar
KENNY G
Anyone got any pictures of this fitted on a 2wd box?
jessie_rs
11
Jun 3, 2019 04:57 PM
neil18
Mar 14, 2016 01:08 PM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
