St 170 tuning........
Old May 7, 2010 | 08:47 PM
Pikey735's Avatar
Pikey735
Default St 170 tuning........
Hey guys, I've got an st170 and am considering chucking a bit of money at the motor, I realise that being 160bhp ish out of the box, real gains won't come cheap, I've read about adjusting verniers on stock cams, using different intake ducts etc..... But was wondering if the standard management could be re-calibrated to work with a lairier set of cams, catcams list a few sets, but with the vvt, what options do I have? Has anyone done much research into tuning these without going FI???
Old May 8, 2010 | 09:40 AM
Sp3no's Avatar
Sp3no
Put it this way i have spent nearly 2grand on my ST170's engine and all i have to show for it is 189bhp, there is not allot of tuning potential here as a N/A engine, even with TB's you will only see 220ish, the weak point is the oil pump, they do not like to be revved past 8000rpm so unless you plan to switch to a dry sump set up i would go for forced induction or buy a faster car. Lairy cams generally mean higher revs, even billet oil pump ring gears have been known to fail at high revs. The standard black oak managment is not an easy unit to tune, the best thing you can do is get a generic map unloaded from the likes of Dreamscience.
You can only fit a verier cam to the exhaust pulley due to the VVT on the inlet side, i have a CFM one fitted to mine retarded 6degrees, it gained roughly 5bhp for this mod, torque of the devil will supply fit and set up the pulley for £350
JoeyBoyden
Jan 4, 2024 02:36 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
RsS2daz
Aug 14, 2015 05:26 AM
Bezzy41
Aug 3, 2015 10:31 AM
