Breaking s2 RS turbo cabriolet
Old May 6, 2010 | 08:04 PM
andre_k's Avatar
andre_k
Default Breaking s2 RS turbo cabriolet
i have stripped my s2 rs turbo cabriolet (mfi) that has been stood over 2 years as i have found far to many holes in the shell for my liking, and have practically everything for sale, except the turbo and ecu's
all items in grantham, lincs. pick up only on gearbox, exhaust, kit, roof and bonnet.
s2 LSD gearbox, rebuilt to standard spec only 5k ago £200
roof with no rips £100
Magnex full exhaust from downpipe, rolled in tip, will check sizes in a bit £110
standard engine been stripped as i was going to rebuild it, so will sell block crank etc separate (never been skimmed bored etc)
brakes, master cylinder etc
driveshafts
loom (been cut at sill unfourtunately)
cabby doors SOLD
s2 skirts and arches (no jacking point covers) £25
bonnet with vents (bit of rust coming through) £25 w/o vents £35 with
90 spec front recaros with a couple of fag burns, and wear ususal place on drivers seat £85
heater matrix £10
radiator £35
working metering unit £70
90 spec rs turbo bumper needs paining SOLD
rs turbo bootlid no rust in the usual places £40
o/s headlamp £10
lots of pipes/hoses (standard)
-31 actuator silver with jamsport engraving £35
inlet manifold £10
distributor £30
starter motor £25
altinator £25
throttle
piperx air filter £10
gearleaver unit £10
lots of sensors etc
anything else just ask and i will prob have!
Old May 7, 2010 | 04:20 AM
Blunt.RS's Avatar
Blunt.RS
Hi fella have you got the pressure regulation valves for the brakes and res
insulation on bonnet
Old May 7, 2010 | 06:26 AM
coco16i's Avatar
coco16i
I bought my S2 with no rear shockers fitted so i need the strut top rubbers if you have them mate, i have the rubber sleeves that go over the rear shockers but need the rubber mounts that these sit into if you know what i mean !!!
Price posted please fella.
Old May 7, 2010 | 09:06 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I know it's small but would really appreciate it if you have the two little plastic 'covers' that fit on the top of the doors where the quater window meets the main window?
I'll take a pic of mine in minute so you kno what I mean! lol
Old May 7, 2010 | 01:53 PM
andre_k's Avatar
andre_k
if you mean the valves under the wiper motor, near the engine mount, then yes i do, £15 inc postage, dont think i have the bonnet insulation
Old May 7, 2010 | 01:54 PM
andre_k's Avatar
andre_k
im taking the rear shocks off this weekend so ill have a look, theyre only the standard xr3i shocks, but im sure the bit your after is the same
Old May 7, 2010 | 01:55 PM
andre_k's Avatar
andre_k
if you mean the little plastic angle bits then yes, £4 posted mate
Old May 7, 2010 | 02:06 PM
matthart's Avatar
matthart
have you got the steering column brace bar to the a pillar?
Old May 7, 2010 | 03:13 PM
andre_k's Avatar
andre_k
yes mate ill double check when i get home
Old May 7, 2010 | 04:03 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
Have you got the gearbox mounts, the metal bits that go from the box to the rubber bits? Also the weather strips that are riveted to the A-pillar, between the door and windscreen.
Old May 7, 2010 | 04:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
These mate...
If they are not cracked/snapped then PM me your paypal mate and i'll get you a fiver over as a gift
Old May 7, 2010 | 05:09 PM
andre_k's Avatar
andre_k
yes i have the gearbox mounts, 20 inc postage for the pair, only have the o/s weather strip as the n/s was fooked! id throw it in for free with the mounts...
Old May 7, 2010 | 09:25 PM
coco16i's Avatar
coco16i
Good man, cheers.
Old May 8, 2010 | 12:57 AM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
i'll have them. PM of your details and i'll sort out payment.
Old May 8, 2010 | 01:13 AM
pedro.caribe's Avatar
pedro.caribe
Escort s2 1.6
You have a pm mate
Old May 8, 2010 | 04:45 AM
Blunt.RS's Avatar
Blunt.RS
Cheers fella how do you want the money paypal cheque ?
Old May 8, 2010 | 07:09 AM
rs_turbo_tony's Avatar
rs_turbo_tony
hi mate im after rear speaker pods wots roof like and wot suspenion you have cheers
Old May 8, 2010 | 01:53 PM
andre_k's Avatar
andre_k
rear speaker pods aint the mintest, ill take some pics in a bit.
roof is mint, no rips whatsoever
only standard cabby suspention im afraid, with lowering springs
Old May 8, 2010 | 01:54 PM
andre_k's Avatar
andre_k
yes paypal mate, you have pm
Old May 8, 2010 | 01:57 PM
andre_k's Avatar
andre_k
Originally Posted by pedro.caribe
You have a pm mate
hi mate, i cant post bodykit to brazil, its pick up only due to size. sorry!
Old May 8, 2010 | 01:58 PM
andre_k's Avatar
andre_k
pm sent mate
Old May 9, 2010 | 10:32 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
Payment sent mate.
Old May 10, 2010 | 06:02 AM
Blunt.RS's Avatar
Blunt.RS
Paypaled
I forgot to ask you do you have the brackets with them
Old May 10, 2010 | 01:37 PM
andre_k's Avatar
andre_k
Paypaled
the bracket is on them mate
Old May 10, 2010 | 02:41 PM
Blunt.RS's Avatar
Blunt.RS
Cheers Pal you got PM
Old May 10, 2010 | 07:34 PM
brett_'s Avatar
brett_
have you got, the lil plastic clips that the head lights snap into??
Old May 10, 2010 | 07:36 PM
andre_k's Avatar
andre_k
ill dig them out and see which ones i have, not sure if ive got all but i have some...
Old May 10, 2010 | 11:18 PM
white2lsr's Avatar
white2lsr
Would you post the 90 spec front bumper or at least wrap it so I could arrange a courier?
CheeRS
Old May 11, 2010 | 04:41 PM
brett_'s Avatar
brett_
its the bottom 1's i need pal, not the top 1's
brett
Old May 11, 2010 | 07:59 PM
RONNIE CLARK's Avatar
RONNIE CLARK
do you have the standard wheels
Old May 13, 2010 | 01:22 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
Bits arrived here, cheers.
Old May 13, 2010 | 03:24 PM
Blunt.RS's Avatar
Blunt.RS
Arrived today cheers pal
Old May 13, 2010 | 03:37 PM
diamondrst's Avatar
diamondrst
Wot condition is the rad in and how much posted to london cheers
Old May 13, 2010 | 07:13 PM
andre_k's Avatar
andre_k
CheeRS
sorry mate it went yesterday
Old May 13, 2010 | 07:14 PM
andre_k's Avatar
andre_k
Its seen better days looks wise, but it doesnt leak, and isnt warped., i reckon it would be £15 ish to post, not 100% though...
Old May 13, 2010 | 07:16 PM
andre_k's Avatar
andre_k
yes, but need a refurb really, i think one tyre may be ok, but id change all four. £15 collected mate
Old May 13, 2010 | 07:17 PM
andre_k's Avatar
andre_k
cheers
Old May 13, 2010 | 09:15 PM
andre_k's Avatar
andre_k
brett
hi mate, if you mean the white clip that sits in the bottom of headlamp, £6.50 posted for the pair with the metal clip that holds them in place
the ones that the ball joint adjuster thingy pops into?
Old May 14, 2010 | 11:43 AM
G950KDT's Avatar
G950KDT
hi there andre do you have the drivers door still available? any pics you could post up of condition, any rust etc?
cash waiting, can pay immediately for it to be delivered to KY4 8NR upon price quote for delivery.
thanks
neil
Old May 14, 2010 | 04:17 PM
andre_k's Avatar
andre_k
thanks
neil
hi mate ill put a pics up this evening... i think delivery might be expensive though...
