here we go again,good spark,checked injecters with a noid light working ok,took the inlet fuel pipe off the manifold plenty of pressure,but it just will not start. like i said evertink seems to be working but no fuel getting in the bores because spark pugs are dry,any help guys
cheers
have you done the push paddle down while someone else turns the car over? also check boost hoses for air leaks too. simple i know but i missed it for days.
