cosworth brakes on a s2
hi,i want to fit 4x4 cossie calipers to my s2,what discs do i need,2wd or 4wd??also what is the story at the rear,the car is lowered,if i fit discs will i need to adjust the load sensor?is there any difference between 2 and 4wd discs regards performance,will 2wd non vented be good enough?ta,lee
also,what handbrake cable do i use when converting to discs??
cool,had a look and got the info that i need.its pretty expensive i would say.ill have to get searching for bargains,theres a rear disc conversion on ebay for £180,just need front calipers,ill maybe put up an ad in the wanted section.cheers guys!
Aug 14, 2015 07:29 AM
Red_bull
Aug 9, 2015 08:34 AM
