What turbo?
Old May 4, 2010 | 12:25 PM
woolford's Avatar
woolford
Default What turbo?
Hi i thought a T34 would be best but not sure. it for a zetec turbo want about 350 at wheels?? is roller bearing better??
Help
Thanks
Old May 4, 2010 | 12:30 PM
martysmartie's Avatar
martysmartie
The advantage of a roller bearing turbo is the faster spool up time. T34 is a good all round turbo.
Martin
Old May 4, 2010 | 12:44 PM
woolford's Avatar
woolford
Can a T34 be roller bearing??
Old May 4, 2010 | 01:15 PM
coswurv's Avatar
coswurv
Ive got a nice T35 for sale, im sure that will pull it along fairly well
Old May 4, 2010 | 01:17 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
gt3071 gets my vote
Old May 4, 2010 | 01:19 PM
coswurv's Avatar
coswurv
Originally Posted by Chip
gt3071 gets my vote
Lol, cheers for your info chip.
Old May 4, 2010 | 01:20 PM
lead_foot's Avatar
lead_foot
is awesome
HX30 would be perfect.
Old May 4, 2010 | 02:11 PM
crazycage's Avatar
crazycage
gt3071 gets my vote
a gt28 would be better for that power
Old May 4, 2010 | 02:20 PM
lead_foot's Avatar
lead_foot
is awesome
No GT28 will do 350bhp at the wheels on a Zetec.
Old May 4, 2010 | 02:47 PM
crazycage's Avatar
crazycage
how do you know this if you dont mind me asking? What power could a blacktop do at say 19psi on a gt2871 ?
Old May 4, 2010 | 03:06 PM
lead_foot's Avatar
lead_foot
is awesome
GT2871 52 trim, will be about 350 at the flywheel with 20 psi accoring to the compressor map.
Old May 4, 2010 | 03:15 PM
crazycage's Avatar
crazycage
GT2871 52 trim, will be about 350 at the flywheel with 20 psi accoring to the compressor amap.
and thats only 20psi on the baby trim 52!
Old May 4, 2010 | 03:29 PM
lead_foot's Avatar
lead_foot
is awesome
Even on a 56 trim, compressor map says no.
Old May 4, 2010 | 03:35 PM
Chip's Avatar
Chip
For over 400bhp at the flywheel?
I totally disagree with you, but then what would I know
Old May 4, 2010 | 03:37 PM
crazycage's Avatar
crazycage
yes @20psi, mine does at 1.8bar. Theres more to it than the map.
Old May 4, 2010 | 03:41 PM
lead_foot's Avatar
lead_foot
is awesome
At 1.8 bar and 350whp your off the map mate.
Old May 4, 2010 | 03:43 PM
crazycage's Avatar
crazycage
i know you have mapped a few gt30 cars ,but a 28 can do 400 fly on a zetec
Old May 4, 2010 | 03:45 PM
Chip's Avatar
Chip
If you are talking one of the bigger 28s, then yes im sure it can, but I still think a GT30 is a better choice though as it will do it far more easily and almost certainly with lower EGT's
Old May 4, 2010 | 03:55 PM
crazycage's Avatar
crazycage
now thats a fair point .
Old May 4, 2010 | 04:25 PM
12_Second_rst's Avatar
12_Second_rst
Out of intrest what would the t34 make on a zetec with a .48 and again with a .63
Old May 4, 2010 | 04:29 PM
Chip's Avatar
Chip
Totally depends on the rest of the spec, but on a standard YB for example you tend to gain about 20bhp from the bigger housing.
Old May 4, 2010 | 04:40 PM
12_Second_rst
So what would be the max on say a .48 t34 blackTop with standard cams
Old May 4, 2010 | 04:42 PM
Chip's Avatar
Chip
Ive not built or mapped that configuration of engine so would be guessing.
Things like compression ratio, and what manifolds you use, and what exhaust you use, will all have a bearing though, as will where the cams are timed in of course!
The turbo itself works very well at 350ish though, so thats what I would expect to see comfortably if you get the rest right.
Old May 4, 2010 | 07:52 PM
Rick's Avatar
Rick
True, but pushing a turbo off it's map is the way to get the best reponse and performance, but obviously with reduced life span. Unless you're an OEM, choosing a turbo based on the the compressor map and your desired power isn't the way to go.
Look at a T34 compressor map, the GT28 56 trim flows a fair bit more than that, and they have done 400hp plus many many times.
Rick
Old May 4, 2010 | 09:12 PM
woolford's Avatar
woolford
well im lost..Head will have standard valve size but ported. pistons not sure at min but have focus rs ones for now also not sure on manifold
Old May 6, 2010 | 07:52 PM
woolford's Avatar
woolford
Up
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
