rs turbo emmisions
Old May 3, 2010 | 08:04 PM
rs_turbo_tony's Avatar
rs_turbo_tony
Default rs turbo emmisions
hi all i took my rs convertable for a mot sat morning and it passed mot with flying colours . my co came out at 0.16 % the ppm was 252 . the limit was 4.5 % co and 1200 ppm so car shouldn,t be running at all with how lean they came out . we tried to adjust and revs just went up car drives very well and performs very well so im pickled to fuck . any appinions or advise be great thanks.
Old May 3, 2010 | 08:14 PM
DazC's Avatar
DazC
it should be about 1.5% on KE. You'll need to turn down the idle speed as you adjust it though.
Old May 3, 2010 | 08:20 PM
rs_turbo_tony
hi mate tried to mess around with it at mot gona book into rolling road but did wana sort it as much as i could . should run richer than that its running collins chip, uprated injectors, ignition amp , fifth injector set up , plus loads more
Old May 9, 2010 | 09:02 AM
rs_turbo_tony
any one have any ideas or comments cheeers
Old May 9, 2010 | 09:03 AM
studabear's Avatar
studabear
I would be more concerned with on boost fueling
Old May 9, 2010 | 09:10 AM
rs_turbo_tony
seems to be good but taking rolling road for a power run see wot its doing under load fifth injector bosche 803 for top end fuelling
my worry was idle emissions do i need worry if fuelling good through out rev range. i will take to another garage just in case co reader wrong
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
